[gdal-dev] Projecting nzmg/nzgd49 to nzgd2000
Mike Leahy mgleahy at alumni.uwaterloo.ca
Wed Sep 24 01:13:21 EDT 2008
Hello list,
I'm trying to figure out some issues I'm having with re-projecting some
data located on Stewart Island at the south end of New Zealand.  The
source data are using UTM coordinates projected in New Zealand Map Grid,
based on the New Zealand Geodedic Datum 1949, and I'm reprojecting them
to UTM coordinates using New Zealand Geodedic Datum 2000 (which I guess
is basically WGS84).  The corresponding epsg numbers are 27200 and 2193
respectively.
The problem I've encountered is that if I let gdalwarp or ogr2ogr
automatically detect the NZGD49 projection from the dataset, and specify
the output projection using -t_srs epsg:2193, the output is off by about
165 metres or so.  If I add the parameter -s_srs epsg:27200 to the
gdalwarp/ogr2ogr commands, the output seems to be correct (i.e., it
lines up with coordinates that are similarly reprojected using ESRI's
ArcGIS).  I have posted a sample image of the output here:
http://img210.imageshack.us/my.php?image=projectionsmux9.jpg.  In that
image, the background raster and the red dots were incorrectly projected
(without specifying -s_srs), while the green dots shows how far off
these from their correct locations.
I have included below the SRS WKT definitions based on what I get from
the actual prj file, from ogrinfo, and from what is listed in the
spatial_ref_sys table in PostGIS.
Now that I know this is happening, it's not a major problem...but what
could be the cause?  I don't see anything missing in the WKT vs the
corresponding proj4 text in my epsg file.
I'm using GDAL/OGR 1.5.2 and Proj 4.6.0.
Regards,
Mike
srs wkt from a prj file:
PROJCS["GD_1949_New_Zealand_Map_Grid",GEOGCS["GCS_New_Zealand_1949",DATUM["D_New_Zealand_1949",SPHEROID["International_1924",6378388.0,297.0]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["New_Zealand_Map_Grid"],PARAMETER["False_Easting",2510000.0],PARAMETER["False_Northing",6023150.0],PARAMETER["Longitude_Of_Origin",173.0],PARAMETER["Latitude_Of_Origin",-41.0],UNIT["Meter",1.0]]
srs wkt from ogrinfo (for same dataset as above):
PROJCS["GD_1949_New_Zealand_Map_Grid",GEOGCS["GCS_New_Zealand_1949",DATUM["New_Zealand_Geodetic_Datum_1949",SPHEROID["International_1924",6378388.0,297.0]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["New_Zealand_Map_Grid"],PARAMETER["False_Easting",2510000.0],PARAMETER["False_Northing",6023150.0],PARAMETER["Longitude_Of_Origin",173.0],PARAMETER["Latitude_Of_Origin",-41.0],UNIT["Meter",1.0]]
srs wkt for srid=27200 in PostGIS:
PROJCS["NZGD49 / New Zealand Map
Grid",GEOGCS["NZGD49",DATUM["New_Zealand_Geodetic_Datum_1949",SPHEROID["International
1924",6378388,297,AUTHORITY["EPSG","7022"]],TOWGS84[59.47,-5.04,187.44,0.47,-0.1,1.024,-4.5993],AUTHORITY["EPSG","6272"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4272"]],PROJECTION["New_Zealand_Map_Grid"],PARAMETER["latitude_of_origin",-41],PARAMETER["central_meridian",173],PARAMETER["false_easting",2510000],PARAMETER["false_northing",6023150],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AUTHORITY["EPSG","27200"]]
