[gdal-dev] shapefile field size
Even Rouault even.rouault at mines-paris.org
Wed Sep 24 15:31:20 EDT 2008
A quick reading of your issue let me think you're hitting the "well-known" and
still unresolved issue, reported as http://trac.osgeo.org/gdal/ticket/2286
Le Wednesday 24 September 2008 21:14:11 Clay, Bruce, vous avez écrit :
> Follow on to earlier message.
> I removed the SetLength and SetPrecision from the field specification
> and things are working now.  ArcMap thinks the integer fields are
> Doubles with length of 11 and precision of 11 but the values do not
> appear to be truncated so that is a good thing
> It just seems odd that the OCI driver accepted the size but the
> shapefile driver did not.
> Bruce
> ________________________________
> From: gdal-dev-bounces at lists.osgeo.org
> [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Clay, Bruce
> Sent: Wednesday, September 24, 2008 2:55 PM
> To: gdal-dev at lists.osgeo.org
> Subject: [gdal-dev] shapefile field size
> I have an OGR based application that I am having problems with data
> storage
> Several fields are OFTInteger and several are OFTReal
> When I write a dataset using the OCI driver the integer fields all store
> valid information.
> When I write a dataset using the Shapefile driver the integer fields
> appear to be truncated to shorts. They are defined with a field width of
> 4 bytes.  It almost looks like the data is stored as ASCII because only
> the 4 most significant digits are actually saved in the shapefile.
> Is this the intended operation or is there some extra flag that I need
> to set when I switch between creating an Oracle table and a shapefile?
> Bruce
> This message and any enclosures are intended only for the addressee.
> Please
> notify the sender by email if you are not the intended recipient.  If
> you are
> not the intended recipient, you may not use, copy, disclose, or
> distribute this
> message or its contents or enclosures to any other person and any such
> actions
> may be unlawful.  Ball reserves the right to monitor and review all
> messages
> and enclosures sent to or from this email address.
> Please notify the sender by email if you are not the intended recipient.
> If you are not the intended recipient, you may not use, copy, disclose, or
> distribute this message or its contents or enclosures to any other person
> and any such actions may be unlawful.  Ball reserves the right to monitor
> and review all messages and enclosures sent to or from this email address.
