[gdal-dev] can't derive the projection for a geotiff in Guatemala
John Mitchell mitchelljj98 at gmail.com
Wed Sep 24 16:03:16 EDT 2008
I am having difficulty deriving the EPSG code/projection/Coordinate System
for a geotiff in Guatemala.
Any help would be appreciated.
Below is the gdalinfo listing:
Driver: GTiff/GeoTIFF
Size is 11214, 7860
Coordinate System is `'
Origin = (317049.000000000000000,1659460.000000000000000)
Pixel Size = (0.500000000000000,-0.500000000000000)
Metadata:
  AREA_OR_POINT=Area
  TIFFTAG_SOFTWARE=ERDAS IMAGINE
  TIFFTAG_XRESOLUTION=1
  TIFFTAG_YRESOLUTION=1
  TIFFTAG_RESOLUTIONUNIT=1 (unitless)
Corner Coordinates:
Upper Left  (  317049.000, 1659460.000)
Lower Left  (  317049.000, 1655530.000)
Upper Right (  322656.000, 1659460.000)
Lower Right (  322656.000, 1655530.000)
Center      (  319852.500, 1657495.000)
Band 1 Block=11214x8 Type=Byte, ColorInterp=Red
Band 2 Block=11214x8 Type=Byte, ColorInterp=Green
Band 3 Block=11214x8 Type=Byte, ColorInterp=Blue
Thanks,
John J. Mitchell
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080924/42558c51/attachment.html
