[gdal-dev] Best way to test wheter point is contained in Polygon
Jose Gomez-Dans jgomezdans at gmail.com
Thu Sep 25 12:00:57 EDT 2008
Chris, thanks for your comments
2008/9/25 Christopher Barker <Chris.Barker at noaa.gov>
> Perhaps cumbersome, but in fact, at some level, you are indeed doing a
> rasterization with the P-in-P testing, as you are working with ALL the
> pixels in your raster. I bet it would be a lot faster to rasterize the
> polygons once, rather than doing point-in-polygon tests for every single
> raster point.
You are absolutely right. It's just that you have to call external program
such as gdal_rasterize. Is the rasterization stuff supposed to be available
to the Python GDAL bindings? It would make a lot of sense, I guess.
In the end, I ended up rasterising rather than testing each geometry.
Blindingly fast ;)
Cheer,
Jose
Centre for Terrestrial Carbon Dynamics
Department of Geography, University College London
Gower Street, London WC1E 6BT, UK
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080925/13bd7f18/attachment.html
