[gdal-dev] caching & spatial indexing of shapefiles?
Tom Kazimiers 2voodoo at gmx.de
Thu Sep 25 12:49:39 EDT 2008
Mateusz Loskot schrieb:
> Tom Kazimiers wrote:
>> Hi there,
>> the documentation gave me no real answer to the question if there is
>> something like a caching mechanism for feature request. If I request a
>> feature, is this read from disk every time or somehow cached?
> Tom,
> AFAIK, there is no caching mechanism.
> I've it on my TODO list to develop a thin wrapper on Shapelib or OGR that
> will provide caching support, to minimize disk I/O operations.
>> Another thing I could not find out is how I can activate spatial
>> indexing for shape files - the documentation says I should execute the
>> following SQL command: CREATE SPATIAL INDEX ON tablename [DEPTH N]
>> But what is tablename and how do I know if the spatial index is created?
> Spatial index is automatically activated if OGR Shapefile driver finds
> .qix file for your Shapefile.
> Let's say you have Shapefile called roads.shp|.shx|.dbf
> Tablename is "roards" - a filename without extension.
> Here you can find some real example:
> http://mateusz.loskot.net/?p=227
> Best regards,
Mateusz,
thank you very much :)
Regards,
Tom
