[gdal-dev] opendap on Windows
Michael Sumner mdsumner at utas.edu.au
Mon Sep 29 19:42:32 EDT 2008
Hello,
Thanks so much for you answers - I used your lib path and it seems to
work fine.
Cheers, Mike.
==============Original message text===============
On Tue, 30 Sep 2008 8:13:46 +1000 "Christopher Condit" wrote:
Hi Mike-
> Thank you for the feedback - I have tried copying the
curl/xdr/pthreads
> headers into the libdap/include folder - and editing the top level
> nmake.opt to DODS_DIR. There just were a number of unclear steps (for
> me) so I'll go back and try again, then report back more completely. I
> will provide the full steps if I ever succeed.
Here's my configuration:
DODS_DIR = C:\develop\lib\libdap3.8.2
DODS_LIB = $(DODS_DIR)\lib\libdapMD.lib
$(DODS_DIR)\lib\libdapclientMD.lib
And then I added the includes from the "Tools" distribution to the
include dir (preserving the directory hierarchy). If you're still having
trouble building perhaps attach a copy of the errors from nmake. I'm
also using VS 2005.
> I also gather that the instructions for MSVC  in the GDAL FAQ should
be
> completed - I've only done the "atlbase.h" step as that seemed to
allow
> the build in general to finish. Any idea if the other steps would
> impact the Opendap build?
As far as I know these instructions are for the "Express Edition". I
didn't have to make any changes to my VS installation.
-Chris
===========End of original message text===========
If it wasn't backed-up, then it wasn't important. ~ Anon sysadmin
Mike Sumner (Phd. Candidate)
http://www.antcrc.utas.edu.au/~mdsumner/ http://www.zoo.utas.edu.au/awru/  IASOS/AWRU
University of Tasmania
Private Bag 80
Hobart Tasmania 7001
AUSTRALIA
Email: mdsumner at utas.edu.au
Phone: 03 6226 1752 (W)
       0408599921   (M)
Fax:   03 6226 2745
