[gdal-dev] PAM & nodata values
Tue Sep 30 17:25:51 EDT 2008
Matt,
I have had no problem reproducing your bug.  Could you file a ticket on th
issue.  The following change fixes the bug, but  I need a ticket to push the
fix back into the source tree.
Thanks!
Best regards,
warmerda at iBook% svn diff
Index: nitfdataset.cpp
--- nitfdataset.cpp     (revision 15371)
+++ nitfdataset.cpp     (working copy)
@@ -458,7 +458,7 @@
     if( psImage->bNoDataSet )
         return psImage->nNoDataValue;
     else
-        return -1e10;
+        return GDALPamRasterBand::GetNoDataValue( pbSuccess );
On Tue, Sep 30, 2008 at 8:27 PM, Matt Klaric
<matt at diglib1.cecs.missouri.edu> wrote:
> I'm attempting to set the nodata value on an NITF image and then
> subsequently read this nodata value back out of the image.  However this
> read fails to find the newly set nodata value.  See the attached source
> code and an example image.  You can see that the nodata value is being
> set for (the first band of) the image in the PAM XML file.
> Any ideas?
> FYI....I'm using version 1.5.2.
> Thanks,
> Matt Klaric
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
