[Gdal-dev] xml file for accessing to a wcs server
salwa belasalwa at yahoo.fr
Wed Apr 1 06:36:47 EDT 2009
Hi Frank,
this is my WCS service description file:
<WCS_GDAL>
  <ServiceURL>http://localhost:81/cgi-bin/mapserv.exe?map=NDVI.map&amp;SERVICE=WCS&amp;CRS=EPSG:26191&amp;</ServiceURL>
  <CoverageName>NDVI</CoverageName>
  <supportedCRSs>EPSG:26191</supportedCRSs>
  <PreferredFormat>gtiff</PreferredFormat>
  <GetCoverageExtra>&amp;BBOX=279728,114867,296168,125307&amp;time=2002-11-07</GetCoverageExtra>
  <Version>1.0.0</Version>
  <BlockXSize>551</BlockXSize>
  <BlockYSize>351</BlockYSize>
  <BandCount>1</BandCount>
  <BandIdentifier>bands</BandIdentifier>
  <BandType>Byte</BandType>
</WCS_GDAL>
and the Mapfile :
MAP
  NAME wcs
  STATUS ON
  SHAPEPATH "C:/PROJ/R3"
  INTERLACE ON
  TRANSPARENT ON
  UNITS METERS
  DEBUG ON
PROJECTION
    "init=epsg:26191"
END
LAYER
    NAME "NDVI_index"
    STATUS OFF
    #DATA DATA/NDVI/NDVI_9i2e_R3
    DATA ndvi.shp
    FILTERITEM 'TIME'
    FILTER '%time%'
    UNITS METERS
    TRANSFORM TRUE
    DEBUG ON
    TYPE tileindex
    PROJECTION
      "init=epsg:26191"
    END
    DUMP TRUE
END
LAYER
    NAME "NDVI"
    STATUS OFF
    UNITS METERS
    TRANSFORM TRUE
    DEBUG ON
    TYPE RASTER
    TILEINDEX "NDVI_index"
    PROJECTION
      "init=epsg:26191"
    END
    DUMP TRUE
    METADATA
      "wcs_name"    "NDVI"
      "wcs_label"   "NDVI R3"
      "wcs_abstract" "blabla"
      "wcs_description" "blabla"
      "wcs_bandcount" "1"
      "wcs_rangeset_name"   "bands"
      "wcs_rangeset_label"  "bands"
      "wcs_rangeset_axes" "bands"
      "wcs_formats" "gtiff"
      "wcs_srs"   "EPSG:26191"
      "wcs_extent" "279728 114867 296168 125307"
      "wcs_resolution" "30 30"
      "wcs_timeitem" "_date"
      "wcs_timeposition" '2002-09-01,2002-11-07,2002-12-25,2003-01-26,2003-02-11,2003-02-27,2003-03-31,2003-04-16,2003-05-18,2003-08-31'
    END
END
END
Thanks for help,
Best regards,
belaqziz salwa wrote:
> Hi,
> for Accessing to a WCS server i created a local service description xml
> file,but when i
> tested the gdal_translate command, i have the following error:
> C:\Inetpub\wps>gdal_translate -of GTIFF wcs.xml wcs.tif -srcwin 0 0 547 347
> Input file size is 548, 348
> 0ERROR 1: Returned tile does not match expected band count.
> Open GDAL Datasets:
>   1 N GTiff       -1 547x347x3 /vsimem/wcs/00E2F5F0/wcsresult.dat
Salwa,
It would be helpful if you could provide the WCS service
description file, assuming the WCS service is public.
> I also tried to re-compile gdal, but i have error :
>         cd apps
>         nmake /nologo /f makefile.vc
>         cl /nologo /MD /EHsc /Ox /W3 /D_CRT_SECURE_NO_DEPRECATE
> /D_CRT_NONSTDC_NO_DEPRECATE /DNDEBUG -I..\port -I..\ogr -I..\gcore
> -I..\alg -I..\ogr\ogrsf_frmts   -I..\frmts -I..\alg -I..\ogr
> -I..\ogr\ogrsf_frmts gdalinfo.c  ..\gdal_i.lib /link
> gdalinfo.c
> gdalinfo.obj : error LNK2019: unresolved external symbol
> _GDALAllRegister at 0 referenced in function _main
> gdalinfo.exe : fatal error LNK1120: 1 unresolved externals
> NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio
> 8\VC\BIN\cl.EXE"' : return code '0x2'
That is odd.  I have no opinion on why it is happening.
Best regards,
gdal-dev mailing list
gdal-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/gdal-dev
View this message in context: http://n2.nabble.com/xml-file-for-accessing-to-a-wcs-server-tp2566259p2568314.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
