[gdal-dev] libgrass
Wed Apr 1 10:24:25 EDT 2009
James McManus wrote:
> When I use gdalinfo on a GRASS raster file I get the following error
> message:
> error while loading shared libraries: libgrass_dgl.so: cannot open
> shared object file: No such file or directory
> The libgrass libraries are installed in /usr/lib64 but they all have
> .so.6.3.0 suffix's.
James,
I'm not sure what is up with the above.  Do you have the grass shared
library directory in your LD_LIBRARY_PATH?
 >  When I attempt to compile libgrass from source at:
> http://home.gdal.org/projects/grass/
> I get a configure error:
> checking host system type... Invalid configuration
> `x86_64-unknown-linux-gnu': machine `x86_64-unknown' not recognized
That libgrass is quite ancient now and I don't think it is suitable for
use with modern GRASS or even perhaps modern GDAL.
Best regards,
