[gdal-dev] in memory KML
Mano Marks mmarks at google.com
Wed Apr 1 15:12:46 EDT 2009
Seems like libkml would be a good candidate for handling KML in memory.
On Wed, Apr 1, 2009 at 3:23 AM, Mateusz Loskot <mateusz at loskot.net> wrote:
> Frank Warmerdam wrote:
>> Clay, Bruce wrote:
>>> After a bit more digging I am not sure I asked the right question.
>>> What I want to do is read feature information from a shapefile or other
>>> data source and get a string that contains the feature information encoded
>>> in KML that I can pass directly into Google Earth.  I know I can do this
>>> operation is I open the shapefile write the KML data to disk then open the
>>> kml file up with fopen then read it into memory and send it t Google Earth
>>> but I would like to save the disk write the read operation.
>>> Any thoughts?
>> Bruce,
>> I've skimmed the KML driver and there is no sign that it uses the VSI*L
>> API for file access, so I don't see any way you can write results to a
>> memory buffer without substantial recoding in the kml driver.
> Looks like a candidate for proposal for the GSoC 2009
> Best regards,
> Mateusz Loskot, http://mateusz.loskot.net
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Mano Marks
Geo Developer Advocate
http://twitter.com/ManoMarks
Join me for Google I/O, Google's biggest Developer Conference, in San
Francisco, May 27th and 28th, 2009
http://code.google.com/events/io/
