[gdal-dev] in memory KML
Mano Marks mmarks at google.com
Wed Apr 1 16:23:50 EDT 2009
Yes, we need to develop some more documentation. If you want to use
libkml in your app, we are answering questions on it in the KML
Developer Forum: http://groups.google.com/group/kml-support.
BSD license tends to be pretty liberal, that's why we used it.
On Wed, Apr 1, 2009 at 12:22 PM, Clay, Bruce <bclay at ball.com> wrote:
> LibKml can do the in memory file and a lot of other things but the documentation / examples are rather thin.  There is documentation that tells you what the parameters of a call are supposed to be but not to tell you when to use a given method.  They have several test apps but for the most part they only test a single class at a time.
> For example, I am trying to set the attributes in a kml message.  The leverage expat to do a lot of the xml stuff and the attributes seem to relate directly to the expat attributes and not to the way they are used when OGR creates a KML file.
> There are very few examples shown when I Google on the web for examples.
> All in all it looks quite capable but it takes a bit of digging to find out how to do things.
> Then there is the licenses issue.  I can use it in my app without problems but using it in an open source GDAL plug-in may be an issue.
> Bruce
> -----Original Message-----
> From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Mano Marks
> Sent: Wednesday, April 01, 2009 3:13 PM
> To: Mateusz Loskot
> Cc: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] in memory KML
> Seems like libkml would be a good candidate for handling KML in memory.
> On Wed, Apr 1, 2009 at 3:23 AM, Mateusz Loskot <mateusz at loskot.net> wrote:
>> Frank Warmerdam wrote:
>>> Clay, Bruce wrote:
>>>> After a bit more digging I am not sure I asked the right question.
>>>> What I want to do is read feature information from a shapefile or other
>>>> data source and get a string that contains the feature information encoded
>>>> in KML that I can pass directly into Google Earth.  I know I can do this
>>>> operation is I open the shapefile write the KML data to disk then open the
>>>> kml file up with fopen then read it into memory and send it t Google Earth
>>>> but I would like to save the disk write the read operation.
>>>> Any thoughts?
>>> Bruce,
>>> I've skimmed the KML driver and there is no sign that it uses the VSI*L
>>> API for file access, so I don't see any way you can write results to a
>>> memory buffer without substantial recoding in the kml driver.
>> Looks like a candidate for proposal for the GSoC 2009
>> Best regards,
>> Mateusz Loskot, http://mateusz.loskot.net
>> gdal-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Mano Marks
> Geo Developer Advocate
> http://twitter.com/ManoMarks
> Join me for Google I/O, Google's biggest Developer Conference, in San
> Francisco, May 27th and 28th, 2009
> http://code.google.com/events/io/
> This message and any enclosures are intended only for the addressee.  Please
> notify the sender by email if you are not the intended recipient.  If you are
> not the intended recipient, you may not use, copy, disclose, or distribute this
> message or its contents or enclosures to any other person and any such actions
> may be unlawful.  Ball reserves the right to monitor and review all messages
> and enclosures sent to or from this email address.
Mano Marks
