[Gdal-dev] mapserver c#mapscript with mapinfo data folder
meenu meenu.monu at gmail.com
Thu Apr 2 01:01:02 EDT 2009
hi thanks for the reply...let me describe in detail....i did one website using vs2005 C#  using the available project TutorialMapServer(http://www.paolocorti.net/2006/09/20/mapserver-tutorial-for-c-mapscript-asp-net/)....in that project i am calling gis data in web.config file like as follows
<add key="mapFilePath" value="C:\Documents and Settings\Administrator\Desktop\Mapserver(5.2.1)-Mapscript\data\csharptutorial.map"/>
...everything is working fine ...based on the "csharptutorial.map".......i have a set of gis data folder done by mapinfo professional...in that data folder each layer have 4 files(DAT,.ID,.MAP,.TAB),....
now my requirement is insteadof csharptutorial.map i want to call mapinfo 'data' folder...how it is possible???
View this message in context: http://n2.nabble.com/mapserver-c-mapscript-with-mapinfo-data-folder-tp2568756p2573340.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
