[Gdal-dev] mapserver c#mapscript with mapinfo data folder
meenu meenu.monu at gmail.com
Thu Apr 2 07:22:22 EDT 2009
hi tamas...great answer...wt u said is correct..it was the problem with the extent value...i forgot to change that value....now i foundout extend value using ogrinfo.exe....change the values in map file...lt is working fine ..thank u so much....
regards
meenu
View this message in context: http://n2.nabble.com/mapserver-c-mapscript-with-mapinfo-data-folder-tp2568756p2574602.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
