[gdal-dev] gdal2tiles strangeness
Mano Marks mmarks at google.com
Thu Apr 2 20:50:54 EDT 2009
So, using -p "raster" creates far worse distortion in the KML. I'm back to
not using it. I get distortion only at the highest zoom levels that way.
2009/4/1 Klokan Petr Přidal <klokan at klokan.cz>
> Mano,
> > Thanks for the pointer. So it looks like, right now, there's a bug in
> > gdal2tiles, according to  Jesse? Any news on when that might be fixed?
> Just use this gdal2tiles.py:
> http://maptiler.googlecode.com/svn/trunk/maptiler/gdal2tiles.py
> The issue he is referring is fixed in MapTiler SVN:
> http://code.google.com/p/maptiler/issues/detail?id=9
> Commited in maptiler SVN in r17 on Mar 20, 2009.
> I am proposing to fix all known bugs during this summer as part of
> Google Summer of Code project, and also implement support for OGC WMTS
> standard, publish a stable version of MapTiler
> (http://www.maptiler.org/) and synchronize the code with GDAL SVN.
> Klokan
> > Mano
> > 2009/3/31 Klokan Petr Přidal <klokan at klokan.cz>:
> >> Mano,
> >> If you would like to have both Google Maps and Google Earth
> >> presentation for a global map then you must generate two tile sets,
> >> because Google Maps supports only Mercator tiles (EPSG:900913) and
> >> Google Earth only geodetic (EPSG:4326).
> >> GDAL2Tiles has as a default tile profile 'mercator', it means that it
> >> will warp your input into Spherical Mercator internally.
> >> To create tiles and KML for Google Earth for your EPSG:4326 input data
> >> you should use -p "raster".
> >> From the "gdal2tiles --help":
> >> -k, --force-kml     Generate KML for Google Earth - default for
> 'geodetic'
> >>                        profile and 'raster' in EPSG:4326. For a dataset
> with
> >>                        different projection use with caution!
> >> Detailed description of recommended step by step usage of gdal2tiles
> >> for global maps was posted by Jesse Varner
> >> from CIRES & NOAA/NGDC, who used gdal2tiles for official presentation
> >> of Global magnetic anomaly map EMAG2 (for Google Maps/Earth) at:
> >> http://ngdc.noaa.gov/geomag/data/Google_Maps/EMAG2/index.html
> >> His post is here:
> >> http://groups.google.com/group/maptiler/msg/fe105e27a62711e4
> >> Best regards,
> >> Klokan
> >> On Tue, Mar 31, 2009 at 6:37 PM, Mano Marks <mmarks at google.com> wrote:
> >>> I'm getting started with gdal2tiles, and I'm getting strange results.
> >>> I downloaded a blue marble jpg from NASA:
> >>> http://www.nasa.gov/vision/earth/features/blue_marble.html
> >>> And I ran the following command lines:
> >>> gdal_translate -of VRT -a_srs EPSG:4326 -gcp 0 0 -180 90 -gcp 21600 0
> >>> 180 90 -gcp 21600 10800 180 -90 world_200401.jpg bluemarble1.vrt
> >>> gdalwarp -of VRT -t_srs EPSG:4326 bluemarble1.vrt bluemarble2.vrt
> >>> gdal2tiles -k bluemarble2.vrt
> >>> Of course, the last step took awhile.
> >>> The Google Maps and OpenLayers output was fine. However, the KML had
> >>> some odd results. When loaded directly, it looked fine, but when I
> >>> zoomed out, it appeared that what was the equivalent of zoom 0 and 1
> >>> the images retain a Mercator projection. Is this a known issue, or did
> >>> I do something wrong?
> >>> Mano Marks
> >>> Geo Developer Advocate
> >>> Google, Inc.
> >>> http://twitter.com/ManoMarks
> >>> _______________________________________________
> >>> gdal-dev mailing list
> >>> gdal-dev at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> >> http://blog.klokan.cz/
> >> http://www.oldmapsonline.org/
> > Mano Marks
> > Google, Inc.
Mano Marks
Join me for Google I/O, Google's biggest Developer Conference, in San
Francisco, May 27th and 28th, 2009
http://code.google.com/events/io/
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090402/b5cd1fa2/attachment-0001.html
