[Gdal-dev] how can i get the error msg
Vincent Schut schut at sarvision.nl
Fri Apr 3 02:04:41 EDT 2009
mjollnir wrote:
> It's ok. thanks form your reply.
> can i know the health status of the image file before process it.
You could try opening and reading its contents first? If the file is
bad, I'd say you'd probably get an error somewhere while reading it. On
the command line I'd do this with 'gdalinfo -mm <file>'.
Vincent
