[Gdal-dev] How to enable MSG DRIVER
Apostolos Giannakos agiannas at geo.auth.gr
Mon Apr 6 11:01:24 EDT 2009
Dear Warmerdam,
First i would like to thank you for your immediate response
The problem is that when i run ./configure --with -msg in the /frmts
and it doesn;t find the file
Can you please give me detailed instructions about how to build the
MSG DRIVER because i am quite frunstrated with the whole procedure
Thanks
?????? ?????? ??? Frank Warmerdam <warmerdam at pobox.com>:
> APOSTOLOS wrote:
>> root at root1-desktop:~/frmts# ./configure.in --with-msg
> You should be running ./configure, not ./configure.in.
> Try:
> ./configure --with-msg
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
