[Gdal-dev] How to enable MSG DRIVER
Chaitanya kumar CH chaitanya.ch at gmail.com
Tue Apr 7 09:24:51 EDT 2009
Just compiling the files in frmts/msg is not going to be enough. You
should compile the code from the main directory (that contains the
folders alg,apps,frmts,gcore,ogr,port, etc.). The configure script is
in the same directory. If you want, you can disable other drivers
using the configure script.
On Tue, Apr 7, 2009 at 1:42 PM, APOSTOLOS <agiannas at geo.auth.gr> wrote:
> Dear list
> in order to clear the mess i sum the following things i have made:1) created a folder frmts/msg and extracted there my Wavelet 2.04 2) I followed the instructions for the patch for wavelet and changed the libraries 3) I have also downloaded a patch and saved it in frmts/msg/PublicDecompWT (the patch includes many filles like msgcommand.cpp, msgcommand.h......)
> The only configure like file i found is the one that Frank created. Do i save it in the folder frmts/msg/PublicDecompWT like the others and in order to configure do i have to rename configure.in?
> Thanks in Advance
> On Monday 06 April 2009 16:01:24 Apostolos Giannakos wrote:
>> Dear Warmerdam,
>> First i would like to thank you for your immediate response
>> The problem is that when i run ./configure --with -msg in the /frmts
>> and it doesn;t find the file
> The configure script is in the main directory (i.e., you download the source
> tarball, uncompress it, cd into the created directory, and issue
> your ./configure command).
> Jose
> RSU ■ Dept. of Geography ■ University College ■ Gower St, London WC1E 6BT UK
> EMM ■ Dept. of Geography ■ King's College ■  Strand, London WC2R 2LS UK
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> View this message in context: http://n2.nabble.com/MSG-Interface-tp2024510p2597626.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
Chaitanya kumar CH.
