[gdal-dev] How to free memory allocated by ReadRaster, Python API
Even Rouault even.rouault at mines-paris.org
Wed Apr 8 17:49:08 EDT 2009
Le Wednesday 08 April 2009 23:31:59 Ivan Lucena, vous avez écrit :
> Hi Even,
> D'accord. Good tip.
> Although I am planning to read a relative large number of bands (temporal
> series) I can probably enlarge my query windows and balance the memory load
> that it will take. I would do that if I was developing some kind of
> application. The thing is that Python + GDAL + numpy is a wonderful data
> exploration lab and that is all that I am doing in that case.
> But about your previous reply, I am far from that machine now but I am
> almost sure that am using the latest 'and greatest' trunk code. But I
> probably should run the setup.py again and re-install the extension, right?
Yes, you need to rebuild and install the bindings. In that instance, the leak
was in them, not in the core GDAL library.
> My best regards,
> Ivan
> Even Rouault wrote:
> > And I forgot to mention that if you need to operate on big images, you'll
> > have probably suboptimal/poor performance by just extracting one pixel at
> > a time, as there's a non neglectable overhead for each binding function
> > call, especially that one. I'd advise you to read bigger chunks at once,
> > and then iterate on the result buffer.
> > Le Wednesday 08 April 2009 21:16:18 Lucena, Ivan, vous avez écrit :
> >> Hi,
> >> I have a small Python script that uses ReadRaster to collect some values
> >> in order to do some math.
> >> The problem is that once I run the script through a Python IDE I can see
> >> the memory usage increasing but it does not decrease at the end.
> >> After some runs I got a out of memory crash on the IDE itself
> >> (PythonWin).
> >> My code is something like that:
> >> for b in range(nbands):
> >>   for yoff in range(ysize):
> >>     for xoff in range(xsize):
> >>       buffer =
> >> ds.ReadRaster(xoff,yoff,1,1,1,1,datatype,range(1,1+nbands) #
> >>       # formulas and numpy calls
> >>       buffer = None
> >> ds = None
> >> I am running with all my formulas commented just to isolate the memory
> >> problem. It just reads and does nothing.
> >> Does anybody has any advise on how to free that buffer?
> >> Thanks in advance,
> >> Regards,
> >> Ivan
> >> _______________________________________________
> >> gdal-dev mailing list
> >> gdal-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
