[Gdal-dev] Read and convert MSG2 hrit data with GDAL-MSG DRIVER
Wesley Roberts wroberts at csir.co.za
Thu Apr 9 04:45:11 EDT 2009
Hi  APOSTOLOS
Looks like you could maybe leave out the brackets so
gdal_translate -of MSG(/home/tolis/Desktop/2003/06/05/H-000-MSG2__-MSG2_PAR____-WV_062___-000001___-200802281200-C_) /home/tolis/Desktop/output/outfile.tif
should be
gdal_translate -of MSG /home/tolis/Desktop/2003/06/05/H-000-MSG2__-MSG2_PAR____-WV_062___-000001___-200802281200-C_ /home/tolis/Desktop/output/outfile.tif
Am not sure about the file extension wrt the HRIT image but I think the brackets are whats causing the problem.
In regards to the batch processing of your 96 images, it seems you are working linux and should be able to write a fairly simple bash script to repeat the above command. I am not much of a bash scripter myself but I am sure you can find a tutorial on the net, check out the following for an introduction
http://wooledge.org:8000/BashFAQ#head-590f0a3ee41da32fb949a23423096437367343b0
http://db.glug-bom.org/Documentation/abs-guide/index.html
HTH,
WEsley
>>> APOSTOLOS <agiannas at geo.auth.gr> 04/09/09 10:24 AM >>>
Dear list
First all i would like to thank all the people in the list answered my questions. I finally managed to install MSG DRIVER but i have some questions about how to import and convert HRIT MSG2 images with GDAL
I followed the example of the instructions from http://www.gdal.org/frmt_msg.html but i did not manage  to convert HRIT to tif.
My code bellow
bash: syntax error near unexpected token `('
tolis at ubuntu:~/gdal-1.6.0$
Any suggestions what i am doing wrong?   Also what i realy want is to convert MSG2 HRIT thermal bands  for segments 7 and 8 to images to brightness temperatures. Because i have 96 images per day is there any batch process for this kind of procedure?
Does GDAL support this procedure?
Thanks in advance for your time
View this message in context: http://n2.nabble.com/Read-and-convert-MSG2-hrit-data-with-GDAL-MSG-DRIVER-tp2609915p2609915.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
gdal-dev mailing list
gdal-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/gdal-dev
This message is subject to the CSIR's copyright terms and conditions, e-mail legal notice, and implemented Open Document Format (ODF) standard.
The full disclaimer details can be found at http://www.csir.co.za/disclaimer.html.
This message has been scanned for viruses and dangerous content by MailScanner,
and is believed to be clean.  MailScanner thanks Transtec Computers for their support.
