[gdal-dev] Spherical Mercator projects and overviews?
Thu Apr 9 10:46:26 EDT 2009
Stephen Woodbridge wrote:
> Hi all,
> I have a question regarding imagery in spherical mercator projection in
> geotiff images. Do overviews work correctly?
> For example, I use EPSG:4326 and build lots of overviews and I can zoom
> in and out and pan without a problem. Can I do the same thing with
> EPSG:900913 (spherical mercator projection).
> I'm working with LandSat imagery over large area and scale ranges.
Steve,
I can't see any reason that overviews would not work on spherical
mercator when they work on images in other coordinate systems.  The
overview handling is independent of the georeferencing.
Best regards,
