[gdal-dev] Problem in importing to Google Earth a nitf image converted from a tif image by gdal_translate
mohwawang mohwawang at yahoo.com
Thu Apr 9 11:37:23 EDT 2009
Roger,
I'm using Google Earth Pro 5.0. Thank you for the suggestions.
Google Earth Pro 4.0 also supports importing NITF:
http://earth.google.com/userguide/v4/ug_importdata.html that is for importing your data (including vector data and imagery data) to the Places of Google Earth while http://earth.google.com/userguide/v4/ug_imageoverlays.html is for "Using Image Overlays and 3D Models".
See http://earth.google.com/userguide/v4/ug_layers.html#layers_vs_places for the difference between Layers and Places in GE.
This is the first time I'm importing geo-referenced images to Google Earth Pro and so far I don't have much luck. As I said that I could not use GE to import the NITF images converted from gdal_translate (with EPSG:4326 that is the same projection, Simple Cylindrical projection, or known as Lat/Lon WGS84 that GE uses). So I tried to narrow down the problem. This time I imported to GE an native Erdas IMAGINE image (.img) (with UTM projection that GE supports too) but still failed. The later test case has nothing to do with gdal and is purely a question for GE. That .img image can be opened by both IMAGINE and OpenEV.
The NITF image (converted by gdal_translate) not just could not be opened by GE it could not be opened by ENVI 4.1 either. It can be opened by OpenEV (tightly related to gdal) though. So it could be a problem in either gdal_translate or ENVI (I doubt though) or both.
Thanks.
Mo
--- On Thu, 4/9/09, Roger André <randre at gmail.com> wrote:
> From: Roger André <randre at gmail.com>
> Subject: Re: [gdal-dev] Problem in importing to Google Earth a nitf image  converted from a tif image by gdal_translate
> To: "mohwawang" <mohwawang at yahoo.com>
> Cc: "gdal-dev at lists.osgeo.org" <gdal-dev at lists.osgeo.org>
> Date: Thursday, April 9, 2009, 12:44 AM
> Granted, I haven't tried V 5 yet,
> but your quote also states, "Google Earth Pro or
> EC".  Are you using one of those versions of the
> client?  In any case, if the file opens in OpenEV, chances
> are good that the .ntf generated by gdal is ok, and that
> there is some sort of problem with how Google Earth is
> reading it.  Have you tried emailing the KML support list
> as well?
> On Wed, Apr 8, 2009 at 8:51 PM,
> mohwawang <mohwawang at yahoo.com>
> wrote:
> Google Earth 5.0 supports NITF see
> http://earth.google.com/intl/en/userguide/v5/ug_importdata.html
> [Importing Imagery
> You can open GIS imagery files in Google Earth Pro or EC
> and have the files correctly projected over the proper map
> coordinates in the 3D viewer. Google Earth Pro and EC
> support the following types of GIS imagery:
>     * TIFF (.tif), including GeoTiff and compressed TIFF
> files
>     * National Imagery Transmission Format (.ntf)
>     * Erdas Imagine Images (.img)
> In addition, you can also import the following images.
> Because they do not contain projection information, you must
> manually edit their coordinates for correct positioning:
>     * Atlantis MFF Raster (.hdr)
>     * PCIDSK Database File (.pix)
>     * Portable Pixmap Format (.pnm)
>     * Device Independent Bitmap (.bmp)
> Note - All imagery files must contain the correct
> projection information in order to be accurately
> re-projected by the Google Earth software.]
> Mo
> --- On Wed, 4/8/09, Roger André <randre at gmail.com>
> gdal_translate
> > Date: Wednesday, April 8, 2009, 10:45 PM
> > See http://earth.google.com/userguide/v4/ug_imageoverlays.html#requirements,
> > I don't believe the "NITF (rw+): National
> Imagery
> > Transmission Format" is supported by Google
> Earth.
> > Roger
> > On Wed, Apr 8, 2009 at 3:27 PM,
> > wrote:
> > Hi all,
> > I'm sorry that this is the third time I tried to
> send
> > this message out because I myself didn't get the
> first
> > two through gdal-dev at lists.osgeo.org
> > so I thought others might not get it either.
> > I used gdal_translate to convert a tif image to a
> nitf
> > image as:
> > >gdal_translate -of nitf in.tif out.ntf -co
> ICORDS=G
> > Input file size is 561, 420
> > 0...10...20...30...40...50...60...70...80...90...100
> > done.
> > I can display both in.tif and out.ntf with OpenEV. So
> both
> > in.tif and out.ntf were ok to OpenEV.
> > With a simple Google Earth kml file(specifying the
> > LanLonBox)(printed below) I could import the in.tif
> to
> > Google Earth viewer to the right geo-location. So
> in.tif was
> > ok to GE.
> > However, after replacing the image file name from
> in.tif to
> > out.ntf in the same kml file (printed below) I could
> not
> > import the out.ntf to Google Earth viewer (shown as a
> big
> > red cross in a big red rectangle at the geo-location
> in the
> > GE viewer). So out.ntf was not ok to GE. Any ideal
> about
> > what might cause the problem? Was the use of
> gdal_translate
> > wrong or missing some options? I tried not to use -co
> > ICRODS=G but I got the same problem. Thank you.
> > printed kml for in.tif:
> > <?xml version="1.0"
> > encoding="UTF-8"?>
> > <kml xmlns="http://www.opengis.net/kml/2.2"
> > xmlns:gx="http://www.google.com/kml/ext/2.2"
> > xmlns:kml="http://www.opengis.net/kml/2.2"
> > xmlns:atom="http://www.w3.org/2005/Atom">
> > <GroundOverlay>
> >   <description>
> > *** Meta-Data ***
> >     Lat = 42.808863
> >   </description>
> >     <name>in.tif</name>
> >     <Icon>
> >        <href>in.tif</href>
> > <viewBoundScale>0.75</viewBoundScale>
> >     </Icon>
> >       <LatLonBox>
> <north>42.8093748999134</north>
> <south>42.8082925732318</south>
> <east>-70.887525562763</east>
> <west>-70.8894939447889</west>
> <rotation>-95.909027</rotation>
> >       </LatLonBox>
> > </GroundOverlay>
> > </kml>
> > printed kml for out.ntf: same as in.tif
> > except:
> >     <name>out.ntf</name>
> >     <Icon>
> >        <href>out.ntf</href>
> >     </Icon>
> > Best Regards,
> > Mo Wang
> > gdal-dev mailing list
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
