[gdal-dev] Problem in importing to Google Earth a nitf image converted from a tif image by gdal_translate
mohwawang mohwawang at yahoo.com
Thu Apr 9 16:56:47 EDT 2009
Hi Roger,
gdalinfo gave me only info about coordinates of GCPs but I doubt that are much useful to GE. Any other way (other than using GCP in gdal_translate) to embed the coordinates info to the GeoTIFF file?
Thanks.
Mo
Driver: GTiff/GeoTIFF
Files: gdal_translate_tif_to_gtiff.gtf
Size is 561, 420
Coordinate System is `'
GCP Projection = GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.2572235630016,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433],AUTHORITY["EPSG","4326"]]
GCP[  0]: Id=1, Info=
          (0,0) -> (-70.887525562763,42.8093748999134,0)
GCP[  1]: Id=2, Info=
          (560,0) -> (-70.887525562763,42.8082925732318,0)
GCP[  2]: Id=3, Info=
          (560,419) -> (-70.8894939447889,42.8082925732318,0)
GCP[  3]: Id=4, Info=
          (0,419) -> (-70.8894939447889,42.8093748999134,0)
Metadata:
  AREA_OR_POINT=Area
  TIFFTAG_XRESOLUTION=300
  TIFFTAG_YRESOLUTION=300
  TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
Image Structure Metadata:
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left  (    0.0,    0.0)
Lower Left  (    0.0,  420.0)
Upper Right (  561.0,    0.0)
Lower Right (  561.0,  420.0)
Center      (  280.5,  210.0)
Band 1 Block=561x4 Type=Byte, ColorInterp=Red
Band 2 Block=561x4 Type=Byte, ColorInterp=Green
Band 3 Block=561x4 Type=Byte, ColorInterp=Blue
--- On Thu, 4/9/09, Roger André <randre at gmail.com> wrote:
> From: Roger André <randre at gmail.com>
> Subject: Re: [gdal-dev] Problem in importing to Google Earth a nitf image  converted from a tif image by gdal_translate
> To: "mohwawang" <mohwawang at yahoo.com>
> Cc: "gdal-dev at lists.osgeo.org" <gdal-dev at lists.osgeo.org>
> Date: Thursday, April 9, 2009, 4:30 PM
> Hi Mo,
> What is the gdalinfo output for the GeoTIFF that you
> created?  If you didn't get an error when you tried to
> load it in GE, perhaps the georeferencing in the image
> doesn't quite match what you specified in your KML.
> Roger
> On Thu, Apr 9, 2009 at 1:21 PM,
> mohwawang <mohwawang at yahoo.com>
> wrote:
> Hi Roger,
> My goal is to be able to directly import NITF image to GE
> without using KML. You can see the advantage of this
> application - if it works. I'm glad that you have viewed
> in GE georeferenced imagery created or altered by gdal.
> Maybe you can point out what I did wrong.
> It is good that you asked about GeoTIFF. So I used
> gdal_translate to convert the tif image to a GeoTIFF image.
> I tried to drag and drop the GeoTIFF image to GE but nothing
> happened. I did not see the GeoTIFF image in GE and I did
> not get any error message either.
> I can open the GeoTIFF image with OpenEV and I can read the
> lan/lon coordinates and they are correct. One thing is that
> it seems that OpenEV does not set North to Up. Its
> orientation aligns with the file coordinates - (0,0) is at
> the upper left corner. I then opened tif file in the same
> OpenEV and they match to each other.
> Again, I can import the tif image with its kml to GE but I
> can not import the GeoTIFF to GE (without using kml), it
> seems that nothing happened. I can import the GeoTIFF to GE
> with kml - though that is not what I want. But the GeoTIFF
> is better than the NITF that could not be imported to GE
> even with the same kml.
> What's wrong with GeoTIFF? I mean why I could not
> import it to GE? I listed the gdal_translate command line
> here:
> >gdal_translate -of GTiff tiff.tif gtiff.gtf -a_srs
> EPSG:4326 -gcp 0 0 -70.887525562763 42.8093748999134 -gcp
> 560 0 -70.887525562763 42.8082925732318 -gcp 560 419
> -70.8894939447889 42.8082925732318 -gcp 0 419
> -70.8894939447889 42.8093748999134
> I don't have a .ntif file that was not created by gdal
> to test GE via the "Import Image Tool".
> Thanks.
> Mo
> gdal_translate
> > Date: Thursday, April 9, 2009, 12:47 PM
> > Hi Mo,
> > Thanks for that pointer on the differences between GE
> > Layers and Places.  I'll be sure to take a close
> look
> > at those links.  I've had occasion in the past to
> view
> > georeferenced imagery in Google Earth, much of it
> created or
> > altered by gdal in some way, so this topic interests
> me.
> > I'm curious, is your goal to view the NITF format
> > specifically and to have GE read the internal
> georeferencing
> > info, or is it just to view the image in GE?  It
> sounds
> > like you have already accomplished the latter using a
> KML
> > Ground Overlay and a tif, a method which has also
> worked
> > reliably for me in the past as well. I've also
> had
> > success with PNG and JPEG format files.
> > Since in your .nitf test the georeferencing was
> supplied by
> > the KML file, the red "X" you are getting
> implies
> > to me that the image format isn't being correctly
> > interpreted by GE for some reason.  The fact that
> Envi
> > chokes on it as well does seem to point to gdal as a
> > possible culprit, although the NITF format is not one
> that I
> > have seen very much.  Have you tried importing the
> GeoTIFF
> > version of your file directly into GE Pro as well?
> Also,
> > do you have a .nitf file that was not created by gdal,
> and
> > which you could use to test GE via the "Add
> Image
> > Overlay" tool?
> > Roger
> > On Thu, Apr 9, 2009 at 8:37 AM,
> > wrote:
> > Roger,
> > I'm using Google Earth Pro 5.0. Thank you for the
> > suggestions.
> > Google Earth Pro 4.0 also supports importing NITF:
> > http://earth.google.com/userguide/v4/ug_importdata.html
> > that is for importing your data (including vector data
> and
> > imagery data) to the Places of Google Earth while http://earth.google.com/userguide/v4/ug_imageoverlays.html
> > is for "Using Image Overlays and 3D
> Models".
> > See http://earth.google.com/userguide/v4/ug_layers.html#layers_vs_places
> > for the difference between Layers and Places in GE.
> > This is the first time I'm importing
> geo-referenced
> > images to Google Earth Pro and so far I don't have
> much
> > luck. As I said that I could not use GE to import the
> NITF
> > images converted from gdal_translate (with EPSG:4326
> that is
> > the same projection, Simple Cylindrical projection, or
> known
> > as Lat/Lon WGS84 that GE uses). So I tried to narrow
> down
> > the problem. This time I imported to GE an native
> Erdas
> > IMAGINE image (.img) (with UTM projection that GE
> supports
> > too) but still failed. The later test case has nothing
> to do
> > with gdal and is purely a question for GE. That .img
> image
> > can be opened by both IMAGINE and OpenEV.
> > The NITF image (converted by gdal_translate) not just
> could
> > not be opened by GE it could not be opened by ENVI
> 4.1
> > either. It can be opened by OpenEV (tightly related to
> gdal)
> > though. So it could be a problem in either
> gdal_translate or
> > ENVI (I doubt though) or both.
> > Thanks.
> > Mo
> Google
> > gdal_translate
> > > Date: Thursday, April 9, 2009, 12:44 AM
> > > Granted, I haven't
> > tried V 5 yet,
> > > but your quote also states, "Google Earth
> Pro or
> > > EC".  Are you using one of those versions
> of
> > the
> > > client?  In any case, if the file opens in
> OpenEV,
> > chances
> > > are good that the .ntf generated by gdal is ok,
> and
> > that
> > > there is some sort of problem with how Google
> Earth
> > is
> > > reading it.  Have you tried emailing the KML
> support
> > list
> > > as well?
> > > On Wed, Apr 8, 2009 at 8:51 PM,
> > > wrote:
> > > Google Earth 5.0 supports NITF see
> > > http://earth.google.com/intl/en/userguide/v5/ug_importdata.html
> > > [Importing Imagery
> > > You can open GIS imagery files in Google Earth
> Pro or
> > EC
> > > and have the files correctly projected over the
> proper
> > map
> > > coordinates in the 3D viewer. Google Earth Pro
> and EC
> > > support the following types of GIS imagery:
> > >     * TIFF (.tif), including GeoTiff and
> compressed
> > TIFF
> > > files
> > >     * National Imagery Transmission Format
> (.ntf)
> > >     * Erdas Imagine Images (.img)
> > > In addition, you can also import the following
> > images.
> > > Because they do not contain projection
> information,
> > you must
> > > manually edit their coordinates for correct
> > positioning:
> > >     * Atlantis MFF Raster (.hdr)
> > >     * PCIDSK Database File (.pix)
> > >     * Portable Pixmap Format (.pnm)
> > >     * Device Independent Bitmap (.bmp)
> > > Note - All imagery files must contain the
> correct
> > > projection information in order to be accurately
> > > re-projected by the Google Earth software.]
> > > Mo
> > > --- On Wed, 4/8/09, Roger André <randre at gmail.com>
> to
> > Google
> by
> > > gdal_translate
> > > > Date: Wednesday, April 8, 2009, 10:45 PM
> > > > See http://earth.google.com/userguide/v4/ug_imageoverlays.html#requirements,
> > > > I don't believe the "NITF (rw+):
> > National
> > > Imagery
> > > > Transmission Format" is supported by
> Google
> > > Earth.
> > > > Roger
> > > > On Wed, Apr 8, 2009 at 3:27 PM,
> > > > wrote:
> > > > Hi all,
> > > > I'm sorry that this is the third time I
> tried
> > to
> > > send
> > > > this message out because I myself didn't
> get
> > the
> > > first
> > > > two through gdal-dev at lists.osgeo.org
> > > > so I thought others might not get it
> either.
> > > > I used gdal_translate to convert a tif image
> to
> > a
> > > nitf
> > > > image as:
> > > > >gdal_translate -of nitf in.tif out.ntf
> -co
> > > ICORDS=G
> > > > Input file size is 561, 420
> > 0...10...20...30...40...50...60...70...80...90...100
> > > > done.
> > > > I can display both in.tif and out.ntf with
> > OpenEV. So
> > > both
> > > > in.tif and out.ntf were ok to OpenEV.
> > > > With a simple Google Earth kml
> file(specifying
> > the
> > > > LanLonBox)(printed below) I could import
> the
> > in.tif
> > > to
> > > > Google Earth viewer to the right
> geo-location.
> > So
> > > in.tif was
> > > > ok to GE.
> > > > However, after replacing the image file
> name
> > from
> > > in.tif to
> > > > out.ntf in the same kml file (printed below)
> I
> > could
> > > not
> > > > import the out.ntf to Google Earth viewer
> (shown
> > as a
> > > big
> > > > red cross in a big red rectangle at the
> > geo-location
> > > in the
> > > > GE viewer). So out.ntf was not ok to GE.
> Any
> > ideal
> > > about
> > > > what might cause the problem? Was the use
> of
> > > gdal_translate
> > > > wrong or missing some options? I tried not
> to use
> > -co
> > > > ICRODS=G but I got the same problem. Thank
> you.
> > > > printed kml for in.tif:
> > > > <?xml version="1.0"
> > > > encoding="UTF-8"?>
> > > > <kml xmlns="http://www.opengis.net/kml/2.2"
> > > > xmlns:gx="http://www.google.com/kml/ext/2.2"
> > > > xmlns:kml="http://www.opengis.net/kml/2.2"
> > > > xmlns:atom="http://www.w3.org/2005/Atom">
> > > > <GroundOverlay>
> > > >   <description>
> > > > *** Meta-Data ***
> > > >     Lat = 42.808863
> > > >   </description>
> > > >     <name>in.tif</name>
> > > >     <Icon>
> > > >        <href>in.tif</href>
> > <viewBoundScale>0.75</viewBoundScale>
> > > >     </Icon>
> > > >       <LatLonBox>
> > > <north>42.8093748999134</north>
> > > <south>42.8082925732318</south>
> > > <east>-70.887525562763</east>
> > > <west>-70.8894939447889</west>
> > > <rotation>-95.909027</rotation>
> > > >       </LatLonBox>
> > > > </GroundOverlay>
> > > > </kml>
> > > > printed kml for out.ntf: same as in.tif
> > > > except:
> > > >     <name>out.ntf</name>
> > > >     <Icon>
> > > >        <href>out.ntf</href>
> > > >     </Icon>
> > > > Best Regards,
> > > > Mo Wang
> > > > gdal-dev mailing list
> > > > http://lists.osgeo.org/mailman/listinfo/gdal-dev
