[gdal-dev] Problem with OGRCreateCoordinateTransformation
Fri Apr 10 10:36:43 EDT 2009
Reinaldo Escada Chohfi wrote:
> Hello all,
> We place this piece of code to test how coordinate transformation works
> with OGR.
>         OGRSpatialReference oSourceSRS, oTargetSRS;
>         OGRCoordinateTransformation *poCT;
>         double  x1, y1;
>         oSourceSRS="EPSG:4326";
>         oTargetSRS="EPSG:4989";
>         poCT = OGRCreateCoordinateTransformation( &oSourceSRS,
> &oTargetSRS );
>         x1 = -45.859485925833;
>         y1 = -23.2101365278;
>         printf("%lf %lf \n",x1,y1);
>         if( poCT == NULL || !poCT->Transform( 1, &x1, &y1 ) )
>             printf( "Transformation failed.\n" );
>         else
>             printf( "(-45.859485925833,-23.2101365278) -> (%f,%f)\n",
>                      x1, y1 );
> The program compiles fine, but it gives the following runtime error:
> ERROR 6: Unable to load PROJ.4 library (proj.dll), creation of
> OGRCoordinateTransformation failed.
> Isn't PROj.4 (proj.lib) built in OGR?
Reinaldo,
In the default configuration PROJ.4 is loaded at runtime rather than
being linked against at build time.  This was a slightly peculiar and
unusual decision on my part many years ago.  Do you have PROJ.dll available
in your PATH?  If not, you will need to add it for reprojection support.
Best regards,
