[gdal-dev] Problem in importing to Google Earth a nitf image converted from a tif image by gdal_translate
Vincent Schut schut at sarvision.nl
Tue Apr 14 03:35:54 EDT 2009
Hi Mo,
mohwawang wrote:
> Vincent,
> I tried gdalwarp as:
>> gdalwarp in.tif out.tif
> ERROR 1: Unable to compute a transformation between pixel/line and georeferenced coordinate for in.tif.
> There is no affine transformation and no GCPs.
> I guess gdalwarp needs GCPs in in.tif that does not have GCPs in it.
Ah, sorry about that. I assumed your in.tif had gcp's.
> I also tried gdal_translate again and this time I used -a_ullr as:
>> gdal_translate -of GTiff in.tif out.gtf -a_srs EPSG:4326 -a_ullr -70.887525562763 42.8093748999134 -70.8894939447889 42.8082925732318
> Then gdalinfo showed correct corner coordinates. But GE still could not import the out.gtf.
Well, at least you now have a proper north-up geotiff file with embedded
projection and corner coordinates. I'd say any app that says it supports
geotiffs should be able to read this file correctly.
I am sorry, but I have no idea why GE does not import this file
correctly. I have no GE pro license, and no experience with viewing
geotiff files in GE. You might wish to ask on a GE list/forum...
Regards,
Vincent.
> Mo
>> gdalinfo out.gtf
> Driver: GTiff/GeoTIFF
> Files: out.gtf
> Size is 561, 420
> Coordinate System is:
> GEOGCS["WGS 84",
>     DATUM["WGS_1984",
>         SPHEROID["WGS 84",6378137,298.2572235630016,
>             AUTHORITY["EPSG","7030"]],
>         AUTHORITY["EPSG","6326"]],
>     PRIMEM["Greenwich",0],
>     UNIT["degree",0.0174532925199433],
>     AUTHORITY["EPSG","4326"]]
> Origin = (-70.887525562763003,42.809374899913401)
> Pixel Size = (-0.000003508702363,-0.000002576968290)
> Metadata:
>   AREA_OR_POINT=Area
>   TIFFTAG_XRESOLUTION=300
>   TIFFTAG_YRESOLUTION=300
>   TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
> Image Structure Metadata:
>   INTERLEAVE=PIXEL
> Corner Coordinates:
> Upper Left  ( -70.8875256,  42.8093749)
> Lower Left  ( -70.8875256,  42.8082926)
> Upper Right ( -70.8894939,  42.8093749)
> Lower Right ( -70.8894939,  42.8082926)
> Center      ( -70.8885098,  42.8088337)
> Band 1 Block=561x4 Type=Byte, ColorInterp=Red
> Band 2 Block=561x4 Type=Byte, ColorInterp=Green
> Band 3 Block=561x4 Type=Byte, ColorInterp=Blue
> --- On Fri, 4/10/09, Vincent Schut <schut at sarvision.nl> wrote:
>> From: Vincent Schut <schut at sarvision.nl>
>> Subject: Re: [gdal-dev] Problem in importing to Google Earth a nitf image converted from a tif image by gdal_translate
>> To:
>> Cc: "gdal-dev at lists.osgeo.org" <gdal-dev at lists.osgeo.org>
>> Date: Friday, April 10, 2009, 3:15 AM
>> mohwawang wrote:
>>> Hi Roger,
>>> gdalinfo gave me only info about coordinates of GCPs
>> but I doubt that are much useful to GE. Any other way (other
>> than using GCP in gdal_translate) to embed the coordinates
>> info to the GeoTIFF file?
>> Mo,
>> I doubt GE will read and use your gcp's. And as there is
>> not georeferencing (as: standard geotiff georeferencing) in
>> your tiff, GE will fail to place your image.
>> I'd try to run your tiff through gdalwarp instead of
>> gdal_translate. Good chance that gdalwarp will convert your
>> unprojected image with gcp's into a real projected geotiff.
>> Just try: 'gdalwarp <inimage.tif>
>> <outimage.tif>' and then check your outimage with
>> gdal_info. It should now give you proper lat/lon values for
>> the corner coordinates, instead of pixel indices.
>> Vincent.
>>> Thanks.
>>> Mo
>>> Files: gdal_translate_tif_to_gtiff.gtf
>>> Size is 561, 420
>>> Coordinate System is `'
>>> GCP Projection = GEOGCS["WGS
>> 84",DATUM["WGS_1984",SPHEROID["WGS
>> 84",6378137,298.2572235630016,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433],AUTHORITY["EPSG","4326"]]
>>> GCP[  0]: Id=1, Info=
>>>            (0,0)
>> -> (-70.887525562763,42.8093748999134,0)
>>> GCP[  1]: Id=2, Info=
>>>            (560,0)
>> -> (-70.887525562763,42.8082925732318,0)
>>> GCP[  2]: Id=3, Info=
>>>            (560,419)
>> -> (-70.8894939447889,42.8082925732318,0)
>>> GCP[  3]: Id=4, Info=
>>>            (0,419)
>> -> (-70.8894939447889,42.8093748999134,0)
>>> Metadata:
>>>    AREA_OR_POINT=Area
>> (pixels/inch)
>>>    INTERLEAVE=PIXEL
>>> Corner Coordinates:
>>> Upper Left  (    0.0,
>> 0.0)
>>> Lower Left  (    0.0,  420.0)
>>> Upper Right (  561.0,    0.0)
>>> Lower Right (  561.0,  420.0)
>>> Center      (  280.5,
>> 210.0)
>>> --- On Thu, 4/9/09, Roger André <randre at gmail.com>
>> wrote:
>>>> From: Roger André <randre at gmail.com>
>> by gdal_translate
>>>> To: "mohwawang" <mohwawang at yahoo.com>
>>>> Date: Thursday, April 9, 2009, 4:30 PM
>>>> Hi Mo,
>>>> What is the gdalinfo output for the GeoTIFF that
>> you
>>>> created?  If you didn't get an error when you
>> tried to
>>>> load it in GE, perhaps the georeferencing in the
>> image
>>>> doesn't quite match what you specified in your
>> KML.
>>>> Roger
>>>> On Thu, Apr 9, 2009 at 1:21 PM,
>>>> mohwawang <mohwawang at yahoo.com>
>>>> wrote:
>>>> Hi Roger,
>>>> My goal is to be able to directly import NITF
>> image to GE
>>>> without using KML. You can see the advantage of
>> this
>>>> application - if it works. I'm glad that you have
>> viewed
>>>> in GE georeferenced imagery created or altered by
>> gdal.
>>>> Maybe you can point out what I did wrong.
>>>> It is good that you asked about GeoTIFF. So I
>> used
>>>> gdal_translate to convert the tif image to a
>> GeoTIFF image.
>>>> I tried to drag and drop the GeoTIFF image to GE
>> but nothing
>>>> happened. I did not see the GeoTIFF image in GE
>> and I did
>>>> not get any error message either.
>>>> I can open the GeoTIFF image with OpenEV and I can
>> read the
>>>> lan/lon coordinates and they are correct. One
>> thing is that
>>>> it seems that OpenEV does not set North to Up.
>> Its
>>>> orientation aligns with the file coordinates -
>> (0,0) is at
>>>> the upper left corner. I then opened tif file in
>> the same
>>>> OpenEV and they match to each other.
>>>> Again, I can import the tif image with its kml to
>> GE but I
>>>> can not import the GeoTIFF to GE (without using
>> kml), it
>>>> seems that nothing happened. I can import the
>> GeoTIFF to GE
>>>> with kml - though that is not what I want. But the
>> GeoTIFF
>>>> is better than the NITF that could not be imported
>> to GE
>>>> even with the same kml.
>>>> What's wrong with GeoTIFF? I mean why I could not
>>>> import it to GE? I listed the gdal_translate
>> command line
>>>> here:
>>>>> gdal_translate -of GTiff tiff.tif gtiff.gtf
>> -a_srs
>>>> EPSG:4326 -gcp 0 0 -70.887525562763
>> 42.8093748999134 -gcp
>>>> 560 0 -70.887525562763 42.8082925732318 -gcp 560
>> 419
>>>> -70.8894939447889 42.8082925732318 -gcp 0 419
>>>> -70.8894939447889 42.8093748999134
>>>> I don't have a .ntif file that was not created by
>> gdal
>>>> to test GE via the "Import Image Tool".
>>>> Thanks.
>>>> Mo
>>>>>        Subject: Re:
>> image by
>>>> gdal_translate
>>>>> Date: Thursday, April 9, 2009, 12:47 PM
>>>>>        Hi Mo,
>>>>>        Thanks for that
>> pointer on the differences between GE
>>>>>        Layers and
>> Places.  I'll be sure to take a close
>>>> look
>>>>> at those links.  I've had occasion in the
>> past to
>>>> view
>>>>> georeferenced imagery in Google Earth, much of
>> it
>>>> created or
>>>>> altered by gdal in some way, so this topic
>> interests
>>>> me.
>>>>> I'm curious, is your goal to view the NITF
>> format
>>>>>        specifically
>> and to have GE read the internal
>>>> georeferencing
>>>>> info, or is it just to view the image in
>> GE?  It
>>>> sounds
>>>>> like you have already accomplished the latter
>> using a
>>>> KML
>>>>> Ground Overlay and a tif, a method which has
>> also
>>>> worked
>>>>> reliably for me in the past as well. I've
>> also
>>>> had
>>>>> success with PNG and JPEG format files.
>>      Since in your .nitf test the
>> georeferencing was
>>>> supplied by
>>>>> the KML file, the red "X" you are getting
>>>> implies
>>>>> to me that the image format isn't being
>> correctly
>>>>>        interpreted by
>> GE for some reason.  The fact that
>>>> Envi
>>>>> chokes on it as well does seem to point to
>> gdal as a
>>>>>        possible
>> culprit, although the NITF format is not one
>>>> that I
>>>>> have seen very much.  Have you tried
>> importing the
>>>> GeoTIFF
>>>>> version of your file directly into GE Pro as
>> well?
>>>> Also,
>>>>> do you have a .nitf file that was not created
>> by gdal,
>>>> and
>>>>> which you could use to test GE via the "Add
>>>> Image
>>>>> Overlay" tool?
>>>>>        Roger
>>>>>        On Thu, Apr 9,
>> 2009 at 8:37 AM,
>>>>>        mohwawang
>>>>>        wrote:
>>>>>        Roger,
>>>>>        I'm using
>> Google Earth Pro 5.0. Thank you for the
>>>>>        suggestions.
>>>>>        Google Earth
>> Pro 4.0 also supports importing NITF:
>>>>>        http://earth.google.com/userguide/v4/ug_importdata.html
>>>>>        that is for
>> importing your data (including vector data
>>>> and
>>>>> imagery data) to the Places of Google Earth
>> while http://earth.google.com/userguide/v4/ug_imageoverlays.html
>>>>>        is for "Using
>> Image Overlays and 3D
>>>> Models".
>>>>> See http://earth.google.com/userguide/v4/ug_layers.html#layers_vs_places
>>>>>        for the
>> difference between Layers and Places in GE.
>>>>>        This is the
>> first time I'm importing
>>>> geo-referenced
>>>>> images to Google Earth Pro and so far I don't
>> have
>>>> much
>>>>> luck. As I said that I could not use GE to
>> import the
>>>> NITF
>>>>> images converted from gdal_translate (with
>> EPSG:4326
>>>> that is
>>>>> the same projection, Simple Cylindrical
>> projection, or
>>>> known
>>>>> as Lat/Lon WGS84 that GE uses). So I tried to
>> narrow
>>>> down
>>>>> the problem. This time I imported to GE an
>> native
>>>> Erdas
>>>>> IMAGINE image (.img) (with UTM projection that
>> GE
>>>> supports
>>>>> too) but still failed. The later test case has
>> nothing
>>>> to do
>>>>> with gdal and is purely a question for GE.
>> That .img
>>>> image
>>>>> can be opened by both IMAGINE and OpenEV.
>>>>>        The NITF image
>> (converted by gdal_translate) not just
>>>> could
>>>>> not be opened by GE it could not be opened by
>> ENVI
>>>> 4.1
>>>>> either. It can be opened by OpenEV (tightly
>> related to
>>>> gdal)
>>>>> though. So it could be a problem in either
>>>> gdal_translate or
>>>>> ENVI (I doubt though) or both.
>>>>>        Thanks.
>>>>>        Mo
>>>>>        --- On Thu,
>> importing to
>>>> Google
>> image by
>>>>>        gdal_translate
>>>>>>          Cc:
>>>>>> Date: Thursday, April 9, 2009, 12:44 AM
>>    Granted, I haven't
>>>>> tried V 5 yet,
>>>>>> but your quote also states, "Google Earth
>>>> Pro or
>>>>>> EC".  Are you using one of those
>> versions
>>>> of
>>>>> the
>>>>>> client?  In any case, if the file
>> opens in
>>>> OpenEV,
>>>>> chances
>>>>>> are good that the .ntf generated by gdal
>> is ok,
>>>> and
>>>>> that
>>>>>> there is some sort of problem with how
>> Google
>>>> Earth
>>>>> is
>>>>>> reading it.  Have you tried emailing
>> the KML
>>>> support
>>>>> list
>>>>>> as well?
>>>>>>          On
>> Wed, Apr 8, 2009 at 8:51 PM,
>>    wrote:
>>    Google Earth 5.0 supports NITF see
>>>>>>          http://earth.google.com/intl/en/userguide/v5/ug_importdata.html
>>    [Importing Imagery
>>>>>>          You
>> can open GIS imagery files in Google Earth
>>>> Pro or
>>>>> EC
>>>>>> and have the files correctly projected
>> over the
>>>> proper
>>>>> map
>>>>>> coordinates in the 3D viewer. Google Earth
>> Pro
>>>> and EC
>>>>>> support the following types of GIS
>> imagery:
>>    * TIFF (.tif), including GeoTiff and
>>>> compressed
>>>>> TIFF
>>>>>> files
>>    * National Imagery Transmission Format
>>>> (.ntf)
>>>>>>      * Erdas Imagine
>> Images (.img)
>>>>>>          In
>> addition, you can also import the following
>>>>> images.
>>>>>> Because they do not contain projection
>>>> information,
>>>>> you must
>>>>>> manually edit their coordinates for
>> correct
>>>>> positioning:
>>>>>>      * Atlantis MFF
>> Raster (.hdr)
>>    * PCIDSK Database File (.pix)
>>    * Portable Pixmap Format (.pnm)
>>    * Device Independent Bitmap (.bmp)
>>>>>>          Note
>> - All imagery files must contain the
>>>> correct
>>>>>> projection information in order to be
>> accurately
>>    re-projected by the Google Earth
>> software.]
>>>>>>          Mo
>> On Wed, 4/8/09, Roger André <randre at gmail.com>
>> importing
>>>> to
>>>>> Google
>> tif image
>>>> by
>>>>>> gdal_translate
>>>>>>> Date: Wednesday, April 8, 2009, 10:45
>> PM
>>    See http://earth.google.com/userguide/v4/ug_imageoverlays.html#requirements,
>>    I don't believe the "NITF (rw+):
>>>>> National
>>>>>> Imagery
>>>>>>> Transmission Format" is supported by
>>>> Google
>>>>>> Earth.
>>>>>>> Roger
>>    On Wed, Apr 8, 2009 at 3:27 PM,
>>    wrote:
>>    Hi all,
>>    I'm sorry that this is the third time I
>>>> tried
>>>>> to
>>>>>> send
>>>>>>> this message out because I myself
>> didn't
>>>> get
>>>>> the
>>>>>> first
>>>>>>> two through gdal-dev at lists.osgeo.org
>>    so I thought others might not get it
>>>> either.
>>>>>>> I used gdal_translate to convert a tif
>> image
>>>> to
>>>>> a
>>>>>> nitf
>>>>>>> image as:
>>>>>>>> gdal_translate -of nitf in.tif
>> out.ntf
>>>> -co
>>>>>> ICORDS=G
>>>>>>> Input file size is 561, 420
>> 0...10...20...30...40...50...60...70...80...90...100
>>>>>>> done.
>>>>>>> I can display both in.tif and out.ntf
>> with
>>>>> OpenEV. So
>>>>>> both
>>>>>>> in.tif and out.ntf were ok to OpenEV.
>>    With a simple Google Earth kml
>>>> file(specifying
>>>>> the
>>>>>>> LanLonBox)(printed below) I could
>> import
>>>> the
>>>>> in.tif
>>>>>> to
>>>>>>> Google Earth viewer to the right
>>>> geo-location.
>>>>> So
>>>>>> in.tif was
>>>>>>> ok to GE.
>>    However, after replacing the image file
>>>> name
>>>>> from
>>>>>> in.tif to
>>>>>>> out.ntf in the same kml file (printed
>> below)
>>>> I
>>>>> could
>>>>>> not
>>>>>>> import the out.ntf to Google Earth
>> viewer
>>>> (shown
>>>>> as a
>>>>>> big
>>>>>>> red cross in a big red rectangle at
>> the
>>>>> geo-location
>>>>>> in the
>>>>>>> GE viewer). So out.ntf was not ok to
>> GE.
>>>> Any
>>>>> ideal
>>>>>> about
>>>>>>> what might cause the problem? Was the
>> use
>>>> of
>>>>>> gdal_translate
>>>>>>> wrong or missing some options? I tried
>> not
>>>> to use
>>>>> -co
>>>>>>> ICRODS=G but I got the same problem.
>> Thank
>>>> you.
>>>>>>> printed kml for in.tif:
>>    <?xml version="1.0"
>>    encoding="UTF-8"?>
>>    <kml xmlns="http://www.opengis.net/kml/2.2"
>>    xmlns:gx="http://www.google.com/kml/ext/2.2"
>>    xmlns:kml="http://www.opengis.net/kml/2.2"
>>    xmlns:atom="http://www.w3.org/2005/Atom">
>>    <GroundOverlay>
>>    <description>
>>    *** Meta-Data ***
>>      Lat = 42.808863
>>    </description>
>>      <name>in.tif</name>
>>      <Icon>
>>         <href>in.tif</href>
>> <viewBoundScale>0.75</viewBoundScale>
>>>>>>>      </Icon>
>>        <LatLonBox>
>> <north>42.8093748999134</north>
>> <south>42.8082925732318</south>
>>>>>> <east>-70.887525562763</east>
>> <west>-70.8894939447889</west>
>> <rotation>-95.909027</rotation>
>>    </LatLonBox>
>>    </GroundOverlay>
>>    </kml>
>>    printed kml for out.ntf: same as in.tif
>>    except:
>>      <name>out.ntf</name>
>>      <Icon>
>> <href>out.ntf</href>
>>>>>>>      </Icon>
>>    Best Regards,
>>    Mo Wang
>>>> _______________________________________________
>>>>>>> gdal-dev mailing list
>>    http://lists.osgeo.org/mailman/listinfo/gdal-dev
