[gdal-dev] Geometry.Intersects and .Intersection
Henneke, Amanda M amanda.m.henneke at boeing.com
Thu Apr 16 11:06:45 EDT 2009
Hello everyone-
Has anyone played with Geometry.Intersects or Geometry.Intersection?
I have an instance where the Geometry.Intersects method returns true on
two LinearRings, but then when I do the Intersection, it's returning
nothing (null).  I'm not sure why this would be.  I found a few things
on the web about the versions of FWTools.  I am using 1.3.5 with the C#
API for GDAL/OGR.
Any help/advice would be appreciated.  I've included a code snippet:
                     bool bIntersects = geoRing.Intersect(geoOldRing);
                     if (iPt > 0 && bIntersects)
                        Geometry geoRingDiff =
geoRing.Intersection(geoOldRing);
                        if (geoRingDiff != null)
                           wkbGeometryType gType =
geoRingDiff.GetGeometryType();
                           string text = "";
                           geoRingDiff.ExportToWkt(out text);
                           Console.WriteLine(text);
                           geoRingDiff.CloseRings();
                           geoRingNew = geoRing.Difference(geoRingDiff);
                           geoOldRing = geoRingNew.Clone();
                           // Add the ring to the polygon layer
                           geoPolygon.AddGeometry(geoRingNew);
Thanks,
Amanda
