[gdal-dev] Problems building 1.6.0 with Xerces 2.7 on Solaris 10 / Sparc (1.5.x work)
Rushforth, Peter Peter.Rushforth at NRCan-RNCan.gc.ca
Fri Apr 17 10:54:26 EDT 2009
Peter,
That rings a bell too.  Very good work, though enough to drive
you to distraction if your job is geo not IT!
Good for you for posting your work.
I suggested to sunfreeware.com that they might consider keeping
a build of gdal available from their site, so as to mitigate
issues like this.  I notice they have proj4 available, so it
might be a shorter step to getting the whole system available.
Cheers,
Peter
> -----Original Message-----
> From: Peter J Halls [mailto:P.Halls at york.ac.uk]
> Sent: April 17, 2009 5:53 AM
> To: Rushforth, Peter
> Cc: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] Problems building 1.6.0 with Xerces
> Got it: the problem proved to be libtool!  I've successfully
> built a working version of GDAL 1.6.0 by adding the
> '--without-libtool' to configure and tested this version
> using ogr2ogr to translate a gml file to ESRI Shapefile format.
> Fascinating, as libtool itself is unchanged between 1.5.x and
> 1.6.0, yet will build the one and not the other!  Ho hum.
> Best wishes,
> Peter
> Rushforth, Peter wrote:
> >  Peter,
> > Is it possible that what's in /usr/appl/bin/solaris/sparc/include/
> > is xerces 2.8 or other?
> > Looks like a version issue to me, going by memory.
> > Peter
> >> From: gdal-dev-bounces at lists.osgeo.org
> >> [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of
> Peter J Halls
> >> Sent: April 16, 2009 8:49 AM
> >> To: gdal-dev at lists.osgeo.org
> >> Subject: [gdal-dev] Problems building 1.6.0 with Xerces 2.7 on
> >> Dear All,
> >>     I'm sure that I've done something wrong, but cannot
> see it!  I've
> >> pulled GDAL 1.6.0 and ran the same configure command as for 1.5.x,
> >> seeking to include xerces  (for GML).
> >> Configure failed to find the xerces libraries with both gcc
> >> 3.3 and the Sun compilers; I also had to drop Jasper, as I do not
> >> currently have this.  I got round the xerces problem for the Sun
> >> compilers (but get a new set of errors from gcc) by
> editing configure
> >> to add a reference to the XMLUni header file, as follows:
> >> #include <xercesc/util/XercesDefs.hpp> #include
> >> <xercesc/util/XMLUni.hpp> #include <xercesc/util/PlatformUtils.hpp>
> >> However, GDAL then fails to build, with multiple link
> errors of the
> >> same form as originally generated by configure:
> >> Undefined                       first referenced
> >>   symbol                             in file
> >> int xercesc_2_7::XMLString::compareString(const unsigned
> >> short*const,const unsigned short*const)
> >> /usr/postel/gdal-1.6.0/ogr/ogrsf_frmts/o/.libs/iom_basket.o
> >> unsigned short*xercesc_2_7::XMLString::replicate(const
> >> xercesc_2_7::XMLFormatter&xercesc_2_7::XMLFormatter::operator<
> > <(const unsigned
> >> short*const)
> /usr/postel/gdal-1.6.0/ogr/ogrsf_frmts/o/.libs/writer.o
> >> void xercesc_2_7::XMLString::catString(unsigned
> >> short*const)
> >> xercesc_2_7::LocalFileFormatTarget::LocalFileFormatTarget(const
> >> char*const,xercesc_2_7::MemoryManager*const)
> >> Checking the sources, the header file requests appear to
> be in order,
> >> so it would appear that I have some other problem that is
> masked by
> >> my edit to configure.
> >> My current configure statement is
> >> ./configure 'CC=cc' 'CCC=CC'
> >> '--with-oci-include=/usr/appl/oracle/solaris/solaris32/instant
> > client10_1/sdk/include'
> >> '--with-oci-lib=/usr/appl/oracle/solaris/solaris32/instantclie
> > nt10_1/lib'
> >> '--prefix=/usr/appl/bin/solaris/sparc' '--with-pcraster=internal'
> >> '--with-png=internal' '--with-libtiff=internal'
> >> '--with-geotiff=internal'
> >> '--with-jpeg=internal' '--with-xerces'
> >> '--with-xerces-inc=/usr/appl/bin/solaris/sparc/include/'
> '--with-xerces-lib=/usr/appl/bin/solaris/sparc/lib/libxerces-c.so.27'
> >> '--without-python' '--without-jasper'
> >> Note that I have had to specify the libxerces-c.so.27, rather than
> >> just libxerces-c.so as I did at GDAL 1.5.x - they are the same
> >> version.
> >> I can provide compilation logs, etc., should these be needed to
> >> identify where I've gone wrong.
> >> Thanks and best wishes,
> >> Peter
> >> Peter J Halls, GIS Advisor, University of York
> >> Telephone: 01904 433806     Fax: 01904 433740
> >> Snail mail: Computing Service, University of York,
> Heslington, York
> >> YO10 5DD This message has the status of a private and personal
> >> communication
> >> _______________________________________________
> >> gdal-dev mailing list
> >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Heslington, York YO10 5DD This message has the status of a
> private and personal communication
