[gdal-dev] Gdal2tiles generated Openlayers.html
Klokan Petr Přidal klokan at klokan.cz
Sat Apr 18 12:32:17 EDT 2009
Hi Jukka,
openlayers.html should run directly from the disk same as
googlemaps.html is running...
Did you specify Google Maps API key during generation of the code?
Can you please send me command you used for generation of the tiles
and if possible also a link to the presentation which is not running?
Firebug always help with debugging... but as I know there are no
problems with generated OpenLayers presentation.
Best,
Klokan
On Thu, Apr 16, 2009 at 9:05 AM, Jukka Rahkonen
<jukka.rahkonen at mmmtike.fi> wrote:
> Hi,
> I had a try with gdal2tiles and split an image with it. It worked fine, as well
> as the automatically created Googlemaps application.  However, the also
> automatically created OpenLayers.html does not show the tiles for me when opened
> with browser. Is it supposet to work in a similar way than the googlemaps.html
>  or should I be doing some extra steps, like reading the openlayers.html through
> web server and not directly from local file?
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://blog.klokan.cz/
http://www.maptiler.org/
http://www.oldmapsonline.org/
