[gdal-dev] build gdal-1.6.0 on CentOS Linux error
Tue Apr 21 00:27:08 EDT 2009
Gong, Shawn (Contractor) wrote:
> Hi list,
> I am trying to build gdal-1.6.0 on a 64-bit CentOS Linux.
> Error message shows that –fPIC must be used.
> However after I have added –fPIC in HDF4.2r4’s CFLAGS in Makefile and in
> Gdal CFLAGS in GDALmake.opt, the error persists:
> /usr/bin/ld: /home/sgong/build_openev/dist/lib/libmfhdf.a(mfsd.o):
> relocation R_X86_64_32 against `a local symbol' can not be used when
> making a shared object; recompile with -fPIC
> Would someone help?
Shawn,
I would guess you haven't rebuilt all portion of the HDF libraries with
-fPIC.  I'd keep working on hdf makefiles.
Best regards,
