[Gdal-dev] HDF5 problem in VS2008 C# Project
Tamas Szekeres szekerest at gmail.com
Fri Apr 24 07:12:30 EDT 2009
You should also add the directories of /bin and /gdal/csharp to your PATH
environment, or copy all the dll-s into your executing directory to make it
available to load by the application.
The gdalinfo csharp example is not equal to the C++ command line tool you
have to use the simple form:
gdalinfo {GDAL dataset name}
Best regards,
Tamas
2009/4/24 Sunny K <shkwak74 at nate.com>
> Thanks for your reply.
> I set the GDAL_DRIVER_PATH environment variable.
> And I can execute gdalinfo.exe of C++ version.
> In gdalinfo.exe of C# version, I cannot still execute it.
> So, I tried to execute this command using other format (ex. GTIFF, HFA), it
> was failed.
>   "ERROR 4: 'gtiff' does not exxist in the file system, and is not
> recignised as a supported dataset name."
> Does I need any other settings?
> Thanks,
> Sunny
> Tamas Szekeres wrote:
> > Sunny,
> > The HDF5 driver is compiled as a plugin. You have to put the
> corresponding
> > dll (gdal_HDF5.dll, gdal_HDF5Image.dll) from the /bin/gdal/plugins
> > directory to the /gdalplugins subdirectory from where your application is
> > running.
> > Alternatively you can set the GDAL_DRIVER_PATH environment variable to
> > point
> > to the directory where the plugin dll-s are located.
> > Best regards,
> > Tamas
> >> Hi all,
> >> I installed gdal library (release-1500-x64-gdal-1-6-mapserver-5-2.zip),
> >>  but
> >> have some problems.
> >> -       Windows vista 64bit
> >> -       Visual Studio 2008 Standard.
> >> I want to process hdf5 file.
> >> When I executed following command, the error message was printed.
> >> % gdalinfo hdf5
> >> % ERROR 1: --format option given with format 'hdf5', but that format not
> >> recognised.  Use the --formats option to get a list of available
> formats,
> >> and use the short code (ie. GTiff or HFA) as the format identifier.
> >> I'd appreciate it if you would tell me some information to solve this
> >> problem.
> >> Best regards,
> >> - sunny
> >> View this message in context:
> http://n2.nabble.com/HDF5-problem-in-VS2008-C--Project-tp2689126p2689126.html
> >> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> >> _______________________________________________
> >> gdal-dev mailing list
> >> gdal-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://n2.nabble.com/HDF5-problem-in-VS2008-C--Project-tp2689126p2691639.html
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090424/9d18b855/attachment-0001.html
