[gdal-dev] ogr2ogr in fwtools 2.3 on windows gml to shp issue
Even Rouault even.rouault at mines-paris.org
Wed Apr 29 13:48:52 EDT 2009
As far as the message "ERROR 1: Too much data inside one element. File
probably corrupted" is concerned, I think that FWTools-2.3.0 showed a
temporary regression where the maximum size for a geometry was limited to
100,000 bytes to avoid reading corrupted/hostile files. This limit was proved
to be too low and raised to 10,000,000 bytes a bit later (see
http://trac.osgeo.org/gdal/ticket/2818) and I believe that this fix went into
FWTools-2.3.1. Unfortunately the FWTools home page isn't well updated and it
only shows 2.3.0 as the latest version. But you can find here FWTools 2.3.1 :
http://home.gdal.org/fwtools/FWTools231.exe
I was able to rename an attribute in a generated .gfs file and ogrinfo
successfully returned the modified attribute name. So you'll have to provide
more details, ideally a small GML file and the modified .gfs demonstrating a
problem.
Best regards,
Even
Le Wednesday 29 April 2009 17:16:11, vous avez écrit :
> Hi,
> Using fwtools 2.3 on windows, I run the ogr2ogr command on a gml file to
> create a shp file.
> I get the following error message:
> C:\Program Files\FWTools2.3.0\>ogr2ogr -f "ESRI Shapefile" peter.shp
> test.gml ERROR 1: Too much data inside one element. File probably corrupted
> When I cut down the number of coordinates in the gml:Polygon (to an extreme
> minimum), the shp file is created.  But I can't do that in real life.
> Also, I want to supply a gfs file to control attribute name mapping.  But
> it seems to be ignored.
> Thanks
> Peter Rushforth
> Technology Advisor / Conseiller technique
> GeoConnections / GéoConnexions
> 650-615 Booth St. / rue Booth
> Ottawa ON K1A 0E9
> E-mail / Courriel: Peter.Rushforth at NRCan-RNCan.gc.ca
> Phone / Télephone: (613) 943-0784
> Fax / telecopier:  (613) 947-2410
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
