[gdal-dev] Binder installer in GDAL trunk has the wrong version
Even Rouault even.rouault at mines-paris.org
Wed Apr 29 15:31:34 EDT 2009
In fact, updating the swig/python/setup.py is documented in point 3) of the
HOWTO-RELEASE procedure. The question is : should be it updated now, during
the development process, or just before producing the first beta/RC.
Le Wednesday 29 April 2009 21:16:05 Lucena, Ivan, vous avez écrit :
> That is what I did:
> C:\Dev\gdal\swig\python> python setup.py bdist_wininst
> And that generates :
> C:\Dev\gdal\swig\python\dist\GDAL-1.6.0.win32-py2.5.exe
> It should be 1.7.0
> C:\Dev\gdal\swig\python>more ..\..\VERSION
> 1.7.0
> The error seams to be at setup.py line 136:
> http://trac.osgeo.org/gdal/browser/trunk/gdal/swig/python/setup.py#L136
> Should I go ahead add a ticket and change it myself?
> Wouldn't be better to read from "..\..\VERSION" instead of hard code it?
> Regards,
> Ivan
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
