[gdal-dev] NITF Jpeg 2000 read support for GeoEye-1
Gong, Shawn (Contractor) Shawn.Gong at drdc-rddc.gc.ca
Tue Aug 4 16:31:32 EDT 2009
hi list,
I have GeoEye-1 data in NITF 2.1 with Jpeg 2000 compression, that needs
to be viewed in OpenEV. I need to build gdal Jpeg 2000 read support.
Kakadu doesn't seem to be suitable as we need to redistribute software
(for non-commercial use). Kakadu needs each end user to purchase
license. Please correct me if I am wrong.
What are the other choices, JP2ECW or JP2MrSID? I downloaded JP2ECW
source. Its Windows project files are rather old (MS VC6).
Would someone share your build experience?  I need to build on Windows
(compiler is Visual Studio 2005/2008) and Linux.
thanks,
Shawn
partial Gdalinfo output:
Driver: NITF/National Imagery Transmission Format
Files: ...ntf
Size is 9376, 28778
Coordinate System is:
GEOGCS["WGS 84",
    DATUM["WGS_1984",
        SPHEROID["WGS 84",6378137,298.257223563,
            AUTHORITY["EPSG","7030"]],
        TOWGS84[0,0,0,0,0,0,0],
        AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich",0,
        AUTHORITY["EPSG","8901"]],
    UNIT["degree",0.0174532925199433,
        AUTHORITY["EPSG","9108"]],
    AUTHORITY["EPSG","4326"]]
GeoTransform =
  -91.43197048929174, -5.898666666666618e-005, -3.474997393722632e-008
  74.58324254794314, -1.599999999984929e-007, 1.506411370191595e-005
Metadata:
  NITF_FHDR=NITF02.10
  NITF_CLEVEL=06
  NITF_STYPE=BF01
  NITF_OSTAID=UNIL
  NITF_FDT= ..
  NITF_FTITLE=_..
  NITF_FSCLAS=U
  NITF_FSCLSY=US
  NITF_FSCODE=
  NITF_FSCTLH=0
  NITF_FSREL=
  NITF_USE00A_ANGLE_TO_NORTH= ..
  NITF_USE00A_MEAN_GSD= ..
  NITF_USE00A_DYNAMIC_RANGE= ..
  NITF_USE00A_OBL_ANG=14.37
  NITF_STDIDC_ACQUISITION_DATE= ..
  NITF_STDIDC_MISSION=OV05
  NITF_STDIDC_PASS=01
  NITF_STDIDC_OP_NUM=000
  NITF_STDIDC_START_SEGMENT=AA
  NITF_STDIDC_REPRO_NUM=00
  NITF_STDIDC_REPLAY_REGEN=000
  NITF_STDIDC_START_COLUMN=001
  NITF_STDIDC_START_ROW=00001
  NITF_STDIDC_END_SEGMENT=AA
  NITF_STDIDC_END_COLUMN=010
  NITF_STDIDC_END_ROW=00029
  NITF_STDIDC_COUNTRY=CA
  NITF_STDIDC_WAC=0036
  NITF_STDIDC_LOCATION= ..
  NITF_USE00A_ROLL_ANG=-08.22
  NITF_USE00A_N_REF=00
  NITF_USE00A_REV_NUM= ..
  NITF_USE00A_N_SEG=001
  NITF_USE00A_MAX_LP_SEG= ..
  NITF_USE00A_SUN_EL= ..
  NITF_USE00A_SUN_AZ= ..
  NITF_FSDCTP=
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090804/2a070840/attachment.html
