[gdal-dev] GDALCreateTPSTransformer :: Problem
Even Rouault even.rouault at mines-paris.org
Wed Aug 5 14:47:53 EDT 2009
I can only point to the API documentation :
http://gdal.org/gdal__alg_8h.html#a30
This is used by GDAL in
http://trac.osgeo.org/gdal/browser/trunk/gdal/alg/gdaltransformer.cpp
----- Original Message -----
To: gdal-dev at lists.osgeo.org
Sent: Wednesday, August 05, 2009 4:15 PM
Subject: [gdal-dev] GDALCreateTPSTransformer :: Problem
Using Gdal Latest 1.6.1
Whenever i pass this Function my Application is Passing..
Any source on the Usage will be Helpful..
///my Gcpcount = 32 and gcps has an array loaded with Source and Target
GCP's
poTransform = GDALCreateTPSTransformer( GCPCount, gcps , 0   );
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
