[gdal-dev] RasterIO Writing Packed RGB data
Martin Chapman chapmanm at pixia.com
Thu Aug 6 18:08:42 EDT 2009
Answered my on question: It is:
outputDataset->RasterIO(GF_Write, 0, 0, width, height, buffer, width,
height, GDT_Byte, numBands, NULL, 3, 3 * width, 1);
Martin
  _____
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Martin Chapman
Sent: Thursday, August 06, 2009 3:51 PM
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] RasterIO Writing Packed RGB data
I'm using the RasterIO method on the GDALDataset object and trying to write
a buffer where the pixels are packed as RGBRGBRGB etc. and having trouble
figuring out what parameters to pass as the pixel, line and band space.  My
desired output is a 3 band geotiff and the source and dest datatype is byte.
Can anyone point me the write direction on how to use those parameters in
this case?
Thanks in advance,
Martin
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090806/a825dd9a/attachment.html
