[gdal-dev] Re: CSV filesize and OVF
bartvde at osgis.nl bartvde at osgis.nl
Fri Aug 7 08:46:07 EDT 2009
FYI, this is fixed after upgrading to GDAL 1.6.1.
Best regards,
Bart
> Hi list,
> I've got a CSV file with about 50.000 lines.
> Running ogrinfo on it directly goes smoothly, but if I access it using an
> ovf file it won't work.
> It will work if I split up the large file in 2 files.
> Is there a known limit I am running into?
> Best regards,
> Bart
