[gdal-dev] Overriding IRasterIO in class derived from GDALRasterBand
Jorge Arévalo jorge.arevalo at gmail.com
Sat Aug 8 11:43:05 EDT 2009
Hello,
2009/8/7 Tamas Szekeres <szekerest at gmail.com>:
> Just thinking out loadly;
> Wouldn't it be easier to implement that cache at the driver level, just by
> composing the raster in a temp image buffer and feed that image in the
> subsequent IReadBlock calls? I think we should also think about the non
> regular and overlapping blocks which should also be covered by the
> implementation here.
And this buffer, would it be part of the Dataset, as a property?
What's the common way of reading data with a GDAL driver? I suppose
that the sequence is like this:
User's program --> GDALRasterBand::RasterIO --> Format specific
IRasterIO --> Format specific IReadBlock.
If the format speficic IRasterIO is not implemented, the generic
GDALRasterBand::IRasterIO is called, and this method calls IReadBlock
if needed (by GetLockedBlockRef).
Am I right?
If yes, in what point should I implement the cache at "driver level"?
Thanks in advance
Best regards,
Jorge
> Best regards,
> Tamas
>> 2009/8/7 Jorge Arévalo <jorge.arevalo at gmail.com>
>>> > One issue with this concept would be related to the limited memory size
>>> > of
>>> > the particular machine, it may be more reasonable to copy the retrieved
>>> > blocks directly onto the output buffer if possible. In this case you
>>> > cannot
>>> > much rely on the base RasterIO implementation.
>>> So, you suggest to copy the block data into the buffer without calling
>>> base implementation of IRasterIO, do you? This implies take care of
>>> the endianess and pixel size "by hand".
>> And many more... I agree this wouldn't be that straightforward. Populating
>> the block buffer would be much easier.
>> Best regards,
>> Tamas
