[gdal-dev] Re: How would run the geographic query against the shape file via a gdal command line program?
Hermann Peifer peifer at gmx.eu
Sat Aug 8 11:47:17 EDT 2009
John Mitchell wrote:
> I have tried running both gdalwarp and gdal_merge against a subset of
> hundreds of geotiff images via geographic bounding box.
> I would like to speed up the performance by running a geographic query
> against the shape file which was already created via gdaltindex against all
> the geotiff images.
> Next I would like to take the selected objects from the shapefile and use
> the location field to derive all geotiffs which are then used to as source
> to run against gdal_merge or gdalwarp.
> line program?
You could use:
ogrinfo -spat xmin ymin xmax ymax
man ogrinfo says about the spat argument:
> The area of interest. Only features within the rectangle will be reported.
A hack, rather than a solution could be in your case:
TIFF_LIST=$(ogrinfo -ro -al -geom=NO -spat xmin ymin xmax ymax your_index.shp |
awk '/location.*=/{list = list " " $NF}END{print list}')
... followed by:
gdalwarp $TIFF_LIST outfile.tif
The above assumes geotiff file names without spaces. There must be smarter solutions, perhaps by constructing a cutline for galwarp.
Hermann
