[gdal-dev] old autotest http/dods issue - fix
William Kyngesburye woklist at kyngchaos.com
Thu Aug 13 14:43:27 EDT 2009
I keep having this problem in the autotests where the gdalhttp test
ends up using the DODS driver.  I finally fixed it by adding this
after the initial HTTP driver load test, much like the various JP2
tests:
     try:
         drv = gdal.GetDriverByName( 'DODS' )
         drv.Deregister();
         drv.Register()
         print 'Moved DODS'
     except:
         pass
P.S.  is there something wrong with the onearth WMS server used for
the wms test?  The urlopen() check stalls with no timeout.  It didn't
do this in the past.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an
illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
