[gdal-dev] autotest 1.6 errors - need help
Ethan Alpert ealpert at digitalglobe.com
Thu Aug 13 19:17:32 EDT 2009
I'm running on a RHEL5.2 linux box.
-----Original Message-----
From: William Kyngesburye [mailto:woklist at kyngchaos.com]
Sent: Thursday, August 13, 2009 5:07 PM
To: Ethan Alpert
Cc: Even Rouault; gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] autotest 1.6 errors - need help
I haven't tried since then.  Are you also using OSX?
Maybe I should try again, after 2 GDAL updates and a Xerces 3 update...
On Aug 13, 2009, at 5:50 PM, Ethan Alpert wrote:
> Was there ever any resolution to this problem?
> I'm using 1.6 and xerces 3.0. When I try to read GML created with
> GDAL I
> get the following error:
> ERROR 1: <coordinates> element missing value
> From: gdal-dev-bounces at lists.osgeo.org
> [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of William
> Kyngesburye
> Sent: Monday, December 01, 2008 8:13 PM
> To: Even Rouault
> Cc: gdal-dev at lists.osgeo.org
> On Dec 1, 2008, at 12:20 PM, Even Rouault wrote:
>> Yes, ILI/IOM has been fixed, but the GML driver has also been
>> changed so that
>> it behaves correctly with Xerces 3.0. I can confirm that GDAL
>> 1.6.0RC2 passes
>> the GML autotest when compiled and run against xerces-3.0.0 (x86
>> Linux).
>> Are you sure you running a very recent GDAL ? The fix was commited
>> in r15773,
>> on 2008/11/20, between beta2 and RC1.
> Ah, something wrong with Xerces 3, at least with mine.  GDAL 1.6RC3
> now, same errors.  Rebuilt GDAL with Xerces 2.8 and all I get is:
>   TEST: ogr_gml_4 ... fail
>     Wrong featureCode field value
> ILI still succeeds.
> The full set of errors with Xerces 3 is:
>   TEST: ogr_gml_1 ... ERROR 1: <coordinates> element missing value.
> fail (blowup)
> Traceback (most recent call last):
>   File "pymod/gdaltest.py", line 89, in run_tests
>     result = func()
>   File "./ogr_gml_read.py", line 72, in ogr_gml_1
>     if feat.GetField('Name') != 'Aartselaar':
> AttributeError: 'NoneType' object has no attribute 'GetField'
>   TEST: ogr_gml_2 ... ERROR 1: <coordinates> element missing value.
> fail (blowup)
>     result = func()
>   File "./ogr_gml_read.py", line 100, in ogr_gml_2
>     if gml_ds.GetLayerCount() != 1:
> AttributeError: 'NoneType' object has no attribute 'GetLayerCount'
>   TEST: ogr_gml_3 ... ERROR 1: <coordinates> element missing value.
> fail (blowup)
>     result = func()
>   File "./ogr_gml_read.py", line 139, in ogr_gml_3
>     if feat.GetField('ngd_id') != 817792:
>   TEST: ogr_gml_4 ... ERROR 1: <coordinates> element missing value.
> fail (blowup)
>     result = func()
>   File "./ogr_gml_read.py", line 181, in ogr_gml_4
>     if feat.GetField('featureCode') != 10198:
>   TEST: ogr_gml_5 ... ERROR 1: <coordinates> element missing value.
> success
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
This electronic communication and any attachments may contain confidential and proprietary
information of DigitalGlobe, Inc. If you are not the intended recipient, or an agent or employee
responsible for delivering this communication to the intended recipient, or if you have received
this communication in error, please do not print, copy, retransmit, disseminate or
otherwise use the information. Please indicate to the sender that you have received this
communication in error, and delete the copy you received. DigitalGlobe reserves the
right to monitor any electronic communication sent or received by its employees, agents
or representatives.
