[gdal-dev] Re: Re: Strange things with gdalwarp ...
Rahkonen Jukka Jukka.Rahkonen at mmmtike.fi
Mon Aug 17 16:41:57 EDT 2009
> A promising approach seemed to be to warp/resample the ASTER files one by one and create 1500 separate tiles
> in LAEA projection, as an intermediate step. Then I created a vrt file with gdalbuildvrt and
> gdal_translated it into tiff format. The result did however look odd, as the elevation data in most tiles
> was clipped by NODATA areas of their neighbouring tiles :-(
Did you try to use gdalwarp also for the second step with -srcnodata value [value...]?  I believe you did set some NODATA value in step 1 for the intermediate images.
-Jukka Rahkonen-
