[gdal-dev] Re: Strange things with gdalwarp ...
Even Rouault even.rouault at mines-paris.org
Sat Aug 22 06:28:43 EDT 2009
Selon Mateusz Loskot <mateusz at loskot.net>:
Actually, it would rather belong to
http://trac.osgeo.org/gdal/wiki/UserDocs/GdalWarp
> Adam Nowacki wrote:
> > Some rather counterintuitive gdalwarp behavior: the bigger
> > dfWarpMemoryLimit (-wm setting) the more cpu time will be wasted on
> > warping not existing pixels. Why? Warping begins with the destination
> > window size of entire output image size. If this size is larger than
> > dfWarpMemoryLimit it is split in half along the longest axis and any
> > half that doesn't contain the currently processed source file is
> > discarded. With large dfWarpMemoryLimit this subdivision process will
> > stop early with still large portions of out of source image pixels.
> It's really good piece information that belongs to FAQ
> http://trac.osgeo.org/gdal/wiki/FAQ
> Best regards,
> Mateusz Loskot, http://mateusz.loskot.net
> Charter Member of OSGeo, http://osgeo.org
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
