[gdal-dev] Export HDF-EOS to GeoTIFF
Sun Aug 23 20:35:46 EDT 2009
Denis Rykov wrote:
> I'm trying export raster from HDF-EOS to GeoTIFF. At result I have
> GeoTiff with 143 numbers of GCP.
> There are some thousands GCP at HDF-EOS geolocation SDS. Is OGR drivers
> support only 143 GCP?
Denis,
Normally the HDF4 driver takes only a subset of GCPs to keep the number
managable.  The logic looks like:
/*      Determine whether to use no, partial or full GCPs.              */
     const char *pszGEOL_AS_GCPS = CPLGetConfigOption( "GEOL_AS_GCPS",
                                                       "PARTIAL" );
     int iGCPStepX, iGCPStepY;
     if( EQUAL(pszGEOL_AS_GCPS,"NONE") )
         iGCPStepX = iGCPStepY = 0;
     else if( EQUAL(pszGEOL_AS_GCPS,"FULL") )
         iGCPStepX = iGCPStepY = 1;
     else
         // aim for 10x10 grid or so.
         iGCPStepX = MAX(1,((nXPoints-1) / 11));
         iGCPStepY = MAX(1,((nYPoints-1) / 11));
So if you want them all you can set the configuration variable
GEOL_AS_GCPS to FULL either in the environment or as a commandline
switch ("--config GEOL_AS_GCPS FULL").
Best regards,
