[gdal-dev] Problem with GDALGetProjectionRef
Florian Hillen fhillen at uni-osnabrueck.de
Mon Aug 24 08:03:15 EDT 2009
Hi list,
I was wondering why GDALGetProjectionRef delivers an other result than
gdalinfo from FWTools of course by using the same file.
Here is my code from my qgis plugin:
    if( GDALGetProjectionRef( inputDS ) != NULL )
        OGRSpatialReferenceH inputSRS;
        char *pszProjection;
        pszProjection = (char *) GDALGetProjectionRef( inputDS );
        inputSRS = OSRNewSpatialReference(NULL);
        if( OSRImportFromWkt( inputSRS, &pszProjection ) == CE_None )
            char *prettyWkt = NULL;
            OSRExportToPrettyWkt( inputSRS, &prettyWkt, FALSE );
            QString wktFormat = prettyWkt;
            wktFormat.replace(QString("\n"), QString("<br>"));
            information += "<tr><td>";
            information += tr( "<b>Coordinate System:</b><br>" );
            information += wktFormat;
            information += "</td></tr>";
            CPLFree( prettyWkt );
        else
            information += tr( "<b>Coordinate System11:</b><br> %1" )
                            .arg( GDALGetProjectionRef( inputDS ) );
        OSRDestroySpatialReference( inputSRS );
and the same part from gdalinfo:
    if( GDALGetProjectionRef( hDataset ) != NULL )
        OGRSpatialReferenceH  hSRS;
        pszProjection = (char *) GDALGetProjectionRef( hDataset );
        hSRS = OSRNewSpatialReference(NULL);
        if( OSRImportFromWkt( hSRS, &pszProjection ) == CE_None )
            char	*pszPrettyWkt = NULL;
            OSRExportToPrettyWkt( hSRS, &pszPrettyWkt, FALSE );
            printf( "Coordinate System is:\n%s\n", pszPrettyWkt );
            CPLFree( pszPrettyWkt );
        else
            printf( "Coordinate System is `%s'\n",
                    GDALGetProjectionRef( hDataset ) );
        OSRDestroySpatialReference( hSRS );
gdalinfo delivers the right projection:
PROJCS["unnamed",
    GEOGCS["DHDN",
        DATUM["Deutsches_Hauptdreiecksnetz",
            SPHEROID["Bessel 1841",6377397.155,299.1528128000009,
                AUTHORITY["EPSG","7004"]],
            AUTHORITY["EPSG","6314"]],
GDALGetProjectionRef delivers the following WKT string (some of you know
this from some earlier mails):
PROJCS["unnamed",
GEOGCS["DHDN",
DATUM["unknown",
SPHEROID["unretrievable - using WGS84",6378137,298.257223563]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4314"]],
In the earlier mails I thought that the warp doesn't work correct, but
apparently the warp is correct, because I use the same file for gdalinfo
and in my plugin. So the problem must be GDALGetProjectionRef!?
Can anyone help me with that?
Best regards,
Florian
