[gdal-dev] libgeotiff - svn ; problems running autogen.sh
Massimo Di Stefano massimodisasha at yahoo.it
Fri Aug 28 05:03:04 EDT 2009
Hi All,
i'm tring to install libtiff + libgeotiff from the cvs / svn repository
on a VM running sidux-xfce.
(i need to have gdal and ossim compiled against the same libtiff-
libgeotiff libraries)
unlucky while libtiff compile without problems, libgeotiff give me
error running the script :
./autogen.sh
seems it fails to find proj files, this the log :
sasha at epxbox:/usr/local/src/sorcedep/libgeotiff$ ./autogen.sh
Running aclocal
/usr/bin/m4:configure.ac:71: bad expression in eval: m4_Cursor + 2 + 1
/usr/bin/m4:configure.ac:71: bad expression in eval:  > (79)
/usr/bin/m4:configure.ac:71: bad expression in eval (bad input): 4098
 > (but either projects.h or libproj.a not found!"
  fi
fi
if test "$PROJ_HOME" = "no" ; then
  echo "PROJ.4 support disabled."
elif test "$PROJ_LIB" != "" -a "$PROJ_INC" != "" ; then
  echo "Found $PROJ_LIB"
  echo "Found $PROJ_INC/projects.h"
  LIBS="$PROJ_LIB $LIBS"
  PROJ_INC=-I$PROJ_INC
  PROJ_INC=$PROJ_INC
  $as_echo "@%:@define HAVE_PROJECTS_H 1" >>confdefs.h
  $as_echo "@%:@define HAVE_LIBPROJ 1" >>confdefs.h
  PROJ_CONFIG="yes"
  PROJECTS_H_CONFIG="yes"
else
  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for pj_init in -
lproj" >&5
$as_echo_n "checking for pj_init in -lproj... " >&6; }
if test "${ac_cv_lib_proj_pj_init+set}" = set; then :
  $as_echo_n "(cached) " >&6
else
  ac_check_lib_save_LIBS=$LIBS
LIBS="-lproj -lm $LIBS"
cat confdefs.h - <<_ACEOF >conftest.$ac_ext
/* end confdefs.h.  */
/* Override any GCC internal prototype to avoid an error.
   Use char because int might match the return type of a GCC
   builtin and then its argument prototype would still apply.  */
#ifdef __cplusplus
extern "C"
#endif
char pj_init ();
int
main ()
return pj_init ();
  return 0;
_ACEOF
if ac_fn_c_try_link "$LINENO"; then :
  ac_cv_lib_proj_pj_init=yes
else
  ac_cv_lib_proj_pj_init=no
fi
rm -f core conftest.err conftest.$ac_objext \
    conftest$ac_exeext conftest.$ac_ext
LIBS=$ac_check_lib_save_LIBS
fi
{ $as_echo "$as_me:${as_lineno-$LINENO}: result:
$ac_cv_lib_proj_pj_init" >&5
$as_echo "$ac_cv_lib_proj_pj_init" >&6; }
if test "x$ac_cv_lib_proj_pj_init" = x""yes; then :
  cat >>confdefs.h <<_ACEOF
_ACEOF
  LIBS="-lproj $LIBS"
fi
  for ac_header in projects.h
do :
  ac_fn_c_check_header_mongrel "$LINENO" "projects.h"
"ac_cv_header_projects_h" "$ac_includes_default"
if test "x$ac_cv_header_projects_h" = x""yes; then :
_ACEOF
fi
done
  PROJ_CONFIG="yes"
fi
if test ! x$PROJ_CONFIG = xno; then
  PROJ_IS_CONFIG_TRUE=
  PROJ_IS_CONFIG_FALSE='#'
else
  PROJ_IS_CONFIG_TRUE='#'
fi
if test ! x$PROJECTS_H_CONFIG = xno; then
  PROJECTS_H_IS_CONFIG_TRUE=
  PROJECTS_H_IS_CONFIG_FALSE='#'
else
  PROJECTS_H_IS_CONFIG_TRUE='#'
fi
CSV_CONFIG="no"
  --enable-incode-epsg    Use C code EPSG tables
@%:@ Check whether --enable-incode-epsg was given.
if test "${enable_incode_epsg+set}" = set; then :
  enableval=$enable_incode_epsg;
else
  enable_incode_epsg=no
fi
if test "$enable_incode_epsg" != "no"  -o "$enable_incode_epsg" =
""  ; then
    { $as_echo "$as_me:${as_lineno-$LINENO}: checking if EPSG tables
will be read from .csv files" >&5
$as_echo_n "checking if EPSG tables will be read from .csv files... "
 >&6; }
    { $as_echo "$as_me:${as_lineno-$LINENO}: result: yes" >&5
$as_echo "yes" >&6; }
    CSV_CONFIG="yes"
else
 >&6; }
    { $as_echo "$as_me:${as_lineno-$LINENO}: result: no" >&5
$as_echo "no" >&6; }
fi
if test ! x$CSV_CONFIG = xno; then
  CSV_IS_CONFIG_TRUE=
  CSV_IS_CONFIG_FALSE='#'
else
  CSV_IS_CONFIG_TRUE='#'
fi
ac_config_files="$ac_config_files Makefile libxtiff/Makefile bin/
Makefile"
cat >confcache <<\_ACEOF
# This file is a shell script that caches the results of configure
# tests run on this system so they can be shared between configure
# scripts and configure runs, see configure's option --config-cache.
# It is not useful on other systems.  If it contains results you don't
# want to keep, you may remove or edit it.
# config.status only pays attention to the cache file if you give it
# the --recheck option to rerun configure.
# `ac_cv_env_foo' variables (set or unset) will be overridden when
# loading this file, other *unset* `ac_cv_foo' will be assigned the
# following values.
_ACEOF
# The following way of writing the cache mishandles newlines in values,
# but we know of no workaround that is simple, portable, and efficient.
# So, we kill variables containing newlines.
# Ultrix sh set writes to stderr and can't be redirected directly,
# and sets the high bit in the cache file unless we assign to the vars.
  for ac_var in `(set) 2>&1 | sed -n 's/^\([a-zA-Z_][a-zA-Z0-9_]*\)=.*/
\1/p'`; do
    eval ac_val=\$$ac_var
    case $ac_val in #(
    *${as_nl}*)
      case $ac_var in #(
      *_cv_*)
autom4te: /usr/bin/m4 failed with exit status: 1
aclocal: autom4te failed with exit status: 1
  Something went wrong, giving up!
i also tried to install proj from source (svn) in /usr/local
but nothing changes :-(
please have you any clue or have you any suggestion on how can i
install libgeotiff ?
i'm avaiable for any kind of test.
thanks to All
Massimo.
