[Gdal-dev] PROJ.4 EPSG:28992
Even Rouault even.rouault at mines-paris.org
Wed Dec 2 17:13:27 EST 2009
TomvanTilburg a écrit :
hum, looks a bit like a (mysterious) PROJ.4 issue. The "unknown
projection id" probably referes to the 'sterea' method.
I've found a ticket in the PROJ trac database that seems to be very
similar to your issue : http://trac.osgeo.org/proj/ticket/43
> Hi Even,
> Thanks for replying.
> I don't think GDAL installation is the problem, since trying the same code
> with different geom works fine.
> But I just ran it in the DOS box and got a bit more descriptives:
> WKT:POINT(127576.476563 481237.375)
> POINT (127576.476563 481237.375)
> ERROR 6: Failed to initialize PROJ.4 with `+proj=sterea
> +lat_0=52.15616055555555 +lon_0=5.387638888888889 +k=0.9999079 +x_0=0 +y_0=0
> +ellps=bessel +units=m +no_defs '.
> unknown projection id
> Seems like the projection id (this is the EPSG code?) is the culprit.
> Any new ideas?
> best regards,
>  Tom
> Even Rouault wrote:
>> A few points to check that come to mind :
>> * Did you check that the proj.dll can be loaded by GDAL ? Check an error
>> message about it
>> * Is the GDAL_DATA environment variable correctly set ?
>> * If testepsg.exe is compiled (nmake /f makefile.vc testepsg.exe in apps
>> directory should do), try testepsg EPSG:28992
