[gdal-dev] why aerophoto-strip is black ??
Jan Tappenbeck tappenbeck at widemann.de
Thu Dec 3 08:48:46 EST 2009
hi !
it is very difficult - i open the 11 files now again in the
OpenEV-Viewer and every time it is ANOTHER picture that will not be show
Did you think it could be a problem by the memory (3 GB) ???
regards jan :-)
CH.... können auch deutsch mailen ?
Gruß Jan :-)
Chaitanya kumar CH schrieb:
> Jan,
> Can you provide the gdalinfo of the individual strips?
> On Thu, Dec 3, 2009 at 6:35 PM, Jan Tappenbeck <tappenbeck at widemann.de> wrote:
>> hi !
>> i had 11 strip-images of aerophotos with total 200MB.
>> i want to merge this with gdal_merge.py by using FWTools in Windows.
>>> gdal_merge -v -o file.tif -of GTIFF --co --optfile filelist.txt
>> the result is a file with 8.85 GB. when i open the file in OpenEV one of
>> the image-strip will not show ! it is black.
>> look at http://www.tappenbeck.net/forum/gdal/gdal_merge_missing_strip.jpg -
>> there is a picture of this result in OpenEV.
>> then i try to make a workaround and translate every ecw to tif - open eveny
>> one to controll -> ok.
>> in the next step i merge these 11 strips to one tif-file with gdal_merge
>> but the result - one strip is missing !
>> can anybody help me ??
>> regards Jan .-)
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
Freundliche Grüße
i.A. Jan Tappenbeck
Dipl. Vermessungsingenieur
CAD-Systemberater & AutoCAD-Support
Widemann Systeme GmbH
CAD- und GIS-Systemhaus
Wiesbaden · Hamburg · München · Düsseldorf · Saarbrücken
Ackermannstraße 21, 22087 Hamburg
Fon: 040 / 229477-22
Fax: 040 / 229477-29
tappenbeck at widemann.de    www.widemann.de
Sitz der Gesellschaft: Wiesbaden, Amtsgericht Wiesbaden HRB 23345
Zu jedem Produkt das passende Forum unter http://www.widemann.de/wisysforen/
Widemann Systeme - aktuell:
geosi.DE - Vermessungssoftware ...
... für Straßenbau, Bauwesen, ....
- weitere Infos unter:
http://www.widemann.de/produkte/geoside/geosi.htm
Diese E-Mail enthält vertrauliche oder rechtlich geschützte Informationen.
Wenn Sie nicht der beabsichtigte Empfänger sind, informieren Sie bitte
sofort den Absender und löschen Sie diese E-Mail. Das unbefugte Kopieren
dieser E-Mail oder die unbefugte Weitergabe der enthaltenen Informationen
ist nicht gestattet.
The information contained in this message is confidential or protected by
law. If you are not the intended recipient, please contact the sender and
delete this message. Any unauthorised copying of this message or unauthorised
distribution of the information contained herein is prohibited.
