[Gdal-dev] how to write out a tiff file using GDAL?
cudars cudars at yeah.net
Fri Dec 4 09:16:27 EST 2009
I am quite new to GDAL.
I want to read a big remote sensing image (tiff file format),do the digital
image process, then write the result to a tiff file. The program language is
C++.
I have finished read in the digital image file and digital image processing.
As the image file has several bands. I do not know how to write out a tiff
file.
Should I use create or createcopy?  The gdalenhance source code using
VRTDataset. In my case, should I use VRTDataset ?  I did not understand the
gdalenhance source code so far.
Could anyone give me a example to illustrate how to write out a tiff file in
GDAL?
Thanks in advanced.
View this message in context: http://n2.nabble.com/how-to-write-out-a-tiff-file-using-GDAL-tp4112637p4112637.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
