[Gdal-dev] import gdal error in python
Even Rouault even.rouault at mines-paris.org
Sat Dec 5 05:00:44 EST 2009
GDAL Python bindings are not compatible with Python 3. I'm even
surprised you managed to build them because the setup.py script doesn't
work with Python 3.
You need a Python 2.X version to make them work.
cudars a écrit :
> python 3.1.1
> gdal 1.6.2
> There are no errors during I built the gdal and python. The installtion is
> ok.
> But when I type import gdal in python, I got the error as follow:
>>>> import gdal
> Traceback (most recent call last):
>   File "<stdin>", line 1, in <module>
>   File "D:\Python31\lib\site-packages\gdal.py", line 295
>     raise ValueError, GetLastErrorMsg()
> SyntaxError: invalid syntax
> I do not what is wrong with this.
> help.
