[gdal-dev] Python 3.X support added for GDAL Python bindings
Even Rouault even.rouault at mines-paris.org
Sun Dec 6 18:44:22 EST 2009
Ivan Lucena a écrit :
To tell the truth, I've tested Python 3.1 and managed to compile the
bindings with an antique VC6.0 (by doing a few horrible hacks in
Python31\Lib\distutils\msvc9compiler.py)
I see that the Python 2.6 distribution has also a
Lib\distutils\msvc9compiler.py file, so I guess it means you can use VC9
with Python 2.6 and later.
> Hi Even,
> Is the Python 3.0 still compiled with VC71? I am asking that because I tried to build a GDAL-Python with VC9 (VS
> 2008 Express Edition) and it usually doesn't work since Python 2.5 was compiled with VC71 (VS 2003).
> Regards,
> Ivan
>>  -------Original Message-------
>>  From: Even Rouault <even.rouault at mines-paris.org>
>>  Subject: [gdal-dev] Python 3.X support added for GDAL Python bindings
>>  Sent: Dec 06 '09 15:43
>>  Folks,
>>  I've just added support for Python 3.X in trunk (
>>  http://trac.osgeo.org/gdal/ticket/3265 ). Compatibility with Python 2.X
>>  has been kept of course.
>>  The bindings are successfully regenerated and autotest suite passes with
>>  both Python 2.3, Python 2.6 and Python 3.1 (except a few OGR tests that
>>  involve non ASCII content that don't pass with Python 3.1)
>>  As this is a pretty massive change (159 files changed), broad testing
>>  would be appreciated to ensure that at least no regression was
>>  introduced when run against Python 2.X
>>  Best regards,
>>  Even
>>  _______________________________________________
>>  gdal-dev mailing list
>>  gdal-dev at lists.osgeo.org
>>  http://lists.osgeo.org/mailman/listinfo/gdal-dev
