[gdal-dev] SWIG Version
Even Rouault even.rouault at mines-paris.org
Tue Dec 8 14:21:07 EST 2009
Benjamin,
Ticket #2928 was fixed for 1.6.1 release. Are the compilation problems
you mention still current with latest SVN trunk ? If so, you should
consider open a new ticket and mention the exact error log you get from
the compiler. But this is a bit surprising as one of our slavebots is a
x64 Windows that uses SWIG 1.3.39 and it can compile the Java bindings.
See szekerest-vc90x64-full slavebot on
http://buildbot.osgeo.org:8500/waterfall
Best regards,
Even
Collins, Benjamin a écrit :
> 1.3.39 produces code that does not compile on x64 Windows (at least with MSVC).  See: http://trac.osgeo.org/gdal/ticket/2928.  The ticket mentions c# bindings but the same is true for the Java bindings.  Rolling back to 1.3.38 fixes the problem.
> Ben
>> -----Original Message-----
>> From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-
>> bounces at lists.osgeo.org] On Behalf Of Even Rouault
>> Sent: Sunday, December 06, 2009 1:22 PM
>> To: Frank Warmerdam
>> Cc: gdal-dev
>> Subject: Re: [gdal-dev] SWIG Version
>> I've been using SWIG 1.3.39 for Java bindings for a few months now, and
>> it's working fine.
>> Frank Warmerdam a écrit :
>>> Folks - particularly swig bindings maintainers,
>>> I have regenerated the swig bindings for python with swig 1.3.39 on
>>> www.gdal.org and committed them.  I used that version to be
>> compatible
>>> with what Even used last time.  However, the scripts that building
>>> the perl and csharp bindings for the nightly snapshots are still
>> using
>>> SWIG 1.3.36.
>>> Before GDAL 1.7 release, I'd like us to settle on a preferred version
>> of
>>> SWIG and I will update this to be the one used for the nightly
>> snapshots
>>> and that we would use at other times for building source
>> distributions.
>>> Is SWIG 1.3.39 acceptable for all bindings maintainers?
>>> PS. SWIG 1.3.39 is built and installed in ~warmerdam/gdal-swig on
>>> www.gdal.org (aka xblade14).   SWIG 1.3.36 is in /usr/local/bin.
>>> Best regards,
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
